Z31 Gearbox Good Condition $300 (want it gone make an offer)S15 Engine 105,000km with everything excluding turbo, fuel injectors and turbo $1,250 (out of car already)
R33 Series 2 Front Calipers with DS2500 pads and 4000DBA discs used only a number of times. $600 (still on car)
6 piston Caliper 336mm rotor WP Pro Brake setup used for 2,000km brade new discs and pads $1200
Work CR KAI Bronze 17x9 +17 set of 2 $700 (Perfect Offset on S13/14/15 front)
Work CR KAI Bronze 18x8.5 +32 set of 2 $500 (one rim damage will have it fixed)
Work CR KAI Bronze 18x9.5 +38 set of 2 $800 (Great Offset on S15 rear)
Semi Slicks R18/265/35 Medium Compound D03G 65% $400 set of 2
Semi Slicks R17/235/45 Medium Compound D03G 40% $300 set of 2
OK condition rear bar $100
1 extra S15 Intake Manifold $100
1 set of urethane engine mounts (used for 2,000km) $80
2 no. S15 standard Exhaust Manifold $100 each
1 no. set n/a SR20 standard cams $150
1 no. Standard S15 throttle body $100
1 no. additional set of Standard S15 Coilpacks $100
All of this needs to go please make an offer.
PM me or call/text me 0428 153 256
Near Ipswich QLD
https://www.sau.com.au/forums/topic/349319-garage-clean-out/
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
