R34 PARTS...THE BODY IS AT THE SCRAP YARD AND THIS IS WHAT'S LEFT
OPEN TO OFFER BECAUSE I WANNA CLEAR THE YARD WILL SWAP PARTS I HAVE FOR SALE
FOR THE ITEM'S LISTED AT THE BOTTOM OF THE PAGE.
>DUMP PIPE (ADVANCED) $80
>AIR BAR STEERING WHEEL $150(MANUAL)
>DRIVERSIDE DOOR WITH GLASS $250
>DRIVERSIDE MIRROR $50
>REAR WINDOW (REMOVED) $150
>DRIVERS DOOR TRIM $100 (HAS WINDOW SWITCH STILL)
>R34 STOCK AIR BOX DAMAGED $50 (ONE CORNER & ONE TAB)$50
>A/C COMPRESSER $100
>A/C CONDENSER $50
>ABS MODULE $100
>BRAKE MASTER $150
>DIFF $200
>REAR BRAKES COMPLETE $400 AS IN PIC)
(lower control arm is bent on one side)
>TAILSHARFT $100
>CLUTCH MASTER $50
>PEDALS $100
>HAND BRAKE HANDLE $50(WITH FRONT CABLE)
>STOCK STRUT BRACE FRONT $25
>IGNITION BARRAL/DOOR/BOOT LOCKS AND A KEY $100
>R34 FRONT CROSSMEMBER $150
>BONNET CABLE/LATCH AND HORN PEICE $50
>R34 CASTOR RODS STOCK $50PAIR
>SR20DET 5 SPEED GEARBOX GOOD CONDITION $350
>HIGH FLOW CAT $100
>Vertex Body Kit to suit lancer 96-03 Coupe (full kit) $500
>DECAT PIPE $50
AND THESE ARE THE ARTS I NEED AND AM WILLING TO SWAP PARTS PLUS CASH FOR THEM..OR IF YOU HAE THESE PARTS CHEAP PM ME.
SR20DET RED TOP/S13 SILVIA
1.GREDDY PULLEY KIT (MOST IMPORTANT AND URGENT)
2.GREDDY/HKS CAMS
3.HKS FUEL RAIL
4.NISMO FPR
5.550CC INJECTORS
6.S13 BN BODY KIT......FRONT / SIDES / REAR
https://www.sau.com.au/forums/topic/349323-r34-parts/
  • 1 month later...
Hey buddy, im after some parts for an R34, here's a link to what i need so if u have them do let me know.. -> http://www.skylinesaustralia.com/forums/topic/355141-r34-gtt-rear-seat-belt-and-front-indicator-holder/
Cheers
https://www.sau.com.au/forums/topic/349323-r34-parts/#findComment-5694622
  • 2 months later...
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
