hey guys, got through the first tank on the new car and got about 250km outta 48ltrs. =about 18L/100. im guessing my o2's have never been replaced so im on the hunt for some. had a brows on the forum but the only place i can find them is at kudos motorsport which are originals for 480bux. anyone know where i can get them from cheaper?? if not them i think ill get the pfc tuned without the o2's working.
https://www.sau.com.au/forums/topic/349334-02-sensors-for-33-gtr/
wiring is no problems. i know the tuning hadnt been done in a long time ten four but it probably needs new ones anyway. i have a look on the new for those o2' and see what i can come up with. i recon the car should be getting around the 14L/100 around town and 12 on the highway. the 18L/100 is on 10psi so its real bad but will get it sorted.
thanks guys
thanks guys
You should be able to get better than the figures you've quoted, however, that depends on your right foot :rolleyes:
will chase that up tomorrow, thanks. also just pulled off the AFM's to clean them and they were very dirty, looks like they haven't been cleaned in a long time. back one had alot of oil on it from the oil breather line so im going to fit a catch can to that side and that should fix that problem.
found this web page http://members.pcug.org.au/~jdeakins/facts.html
got good info on it, looks like i can get them for about 125 each + shipping, part no 0za395-ec. will need to be modified to fit plugs but thats 50% cheaper than the originals.
these are suposed to be the same as the rb25 ones. can anyone confirm that.
will be ringing them back next week to get a price on the boch 0 258 005 726. these are the replacements for r33 and r34 GTR's
ordering two rb25 o2 sensors tomorrow. only one needs a plug change. part number NKT OZA 395-E2 from Kudos Motorsport. $168 for two delivered. These work on R33 and R34 GTR'S but not R32 GTR'S.
Thanks for your help guys
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
    • Change the subframe bushes, transforms the car.
    • For something a little more serious, Davinci Resolve is about the best there is for free video editors. No expiration dates or watermarks, completely free.
    • Well, it's taken me until the last week of 2024 to actually do something on the Skyline but I consider it a good head start to 2025's efforts! I managed to justify (to myself anyway...) my purchase of the lift table. It made taking the rear subframe out a lot easier than it would have been without anyway! Everything is out and stripped down ready for a clean then powdercoating.  She's pretty grubby under there but pretty good condition for a 38 year old Japanese tin bucket. 12 years of zero street time have obviously helped that... I need to decide which of the factory suspension arms I will keep and replace so I only get what I'm keeping powdercoated.  Baby steps but it's a start!
