not sure on that one snoz, the zirconia needs heating to work properly (the two white wires are for heating)but not sure on the titania.
checked my fuel usage and ive hit 190km on half a tank. looks like the dirty afm's could have been a big contributor to the poor fuel economy. should get the new o2 sensors next week, i'll fit them next and see how that goes
Tunes not going to make a huge difference as I doubt nothing mechanically has changed requiring different fuel and ignition loads. Could removing from fuel from the tune by they generally run lean then shift AFM drops when acceleration occurs, so could get some better fuel economy, but I bet it's something like AFM, o2 ect. I've got a set here that are used, but worked fine previously Eric.
Edited by monga
They work like a thermocouple (from my understanding), which means they would read different because of the two different types of materials.
Thanks clint, as i said, got a new set of o2 sensors coming next week, and i will keep a eye on the afm's. if there is any problems with them. 'll come and see you.
are you back from holidays yet? still got to get that price for a set of front rotors off you.
ok makes sense.. but is the difference in material a longetivity thing or do they operate differently due to the difference in material?
operate differently and are not compatible with each other afaik
Edited by JonnoHR31
just fitted the new o2 sensors. had to buy a special socket to get the sensor out (rare as rocking horse poop too). will see if this makes a difference.
If anybody needs to change there o2 sensors and is SOR im quite happy to help as the socket makes it very easy.
if u bought o2 that are RB25 compatible, couldnt u just get the ford EF o2 sensor from repco, as it mentions in the general maintainence section that that is compatable with the RB25, i did that and im sure it was under $100 for it, plus some connectors, and no special tool required,
a bit late now, but might help someone else that is looking thru this thread
I got the o2 sensors for $77each, Gtr sensors are alot harder to get at than the gtst so it was easier to get the correct tool for the job
quote name='ahh 33 s2' timestamp='1295654225' post='5636783']
  • 3 weeks later...
got the fuel economy down to 13.8l/100 without the tune highway/city driving. o2 sensors are working perfectly (pfc sensor check screen). was hoping for a tune by now but other things have come up so it keeps getting put off. knocked up a catch can at work and that is now fitted so hopefully no more oil on the afm's.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
