1989 NISSAN SKYLINE BNR32
84000KMS
Mechanical:
RB26DETT STANDARD ENGINE
NEW THROTTLE BODY GASKETS & INTAKE GASKETS
NEW GARRET 2X 2860-7 TURBOS (5000KMS)
NEW SARD FUEL REG & GUAGE WITH EARLS BRAIDED LINE (5000KMS)
NEW APEXI POWER FC & BOOST CONTROLLER TO SUIT (5000KMS)
NEW APEXI PFC HAND CONTROLLER (5000KMS)
WALBRO FUEL PUMP IN TANK (5000KMS)
NIC CLUTCHES CLUTCH (NOT SURE OF AGE)
DOES HAVE FRONT CRANK SHAFT OIL LEAK (TINY BUT THEY IS WET OIL)
FRONT & REAR SLOTTED ROTORS
Interior:
COMPLETELY STANDARD BESIDES PFC CONTROLLER
DOES HAVE BUBBLE ON DASH DIRECTLY IN FRONT OF PASSANGER
SONY EXPLODE HEAD UNIT
HKS TURBO TIMER
Spare parts:
COMES WITH STANDARD COMPUTER, BOOST SOLINOID & FUEL PUMP
AS SPARES
Condition:
CAR IS IN GREAT CONDITION NO DENTS OR MARKS
HAS 4 BRAND NEW TYRES (4000KMS OLD)
18IN RIMS BIG DISH ON REAR
DARK TINT
Price:
$15000
GOLD COAST, QUEENSLAND
Contact: PM, Reply or call 0408992232 RUSSELL
https://www.sau.com.au/forums/topic/349353-bnr32-gtr-15000/
I can vouch for this car being a serious fast car enthusiast myself . I have been in it on many occasions and i would have bought it by now if i didn't live overseas most of the year. Its such a quick, clean running, smooth and super responsive car. It feels like its on rails!
G
https://www.sau.com.au/forums/topic/349353-bnr32-gtr-15000/#findComment-5620315
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
