Bnr32 Gtr $15000
1989 NISSAN SKYLINE BNR32
84000KMS
Mechanical:
RB26DETT STANDARD ENGINE
NEW THROTTLE BODY GASKETS & INTAKE GASKETS
NEW GARRET 2X 2860-7 TURBOS (5000KMS)
NEW SARD FUEL REG & GUAGE WITH EARLS BRAIDED LINE (5000KMS)
NEW APEXI POWER FC & BOOST CONTROLLER TO SUIT (5000KMS)
NEW APEXI PFC HAND CONTROLLER (5000KMS)
WALBRO FUEL PUMP IN TANK (5000KMS)
NIC CLUTCHES CLUTCH (NOT SURE OF AGE)
DOES HAVE FRONT CRANK SHAFT OIL LEAK (TINY BUT THEY IS WET OIL)
FRONT & REAR SLOTTED ROTORS
Interior:
COMPLETELY STANDARD BESIDES PFC CONTROLLER
DOES HAVE BUBBLE ON DASH DIRECTLY IN FRONT OF PASSANGER
SONY EXPLODE HEAD UNIT
HKS TURBO TIMER
Spare parts:
COMES WITH STANDARD COMPUTER, BOOST SOLINOID & FUEL PUMP
AS SPARES
Condition:
CAR IS IN GREAT CONDITION NO DENTS OR MARKS
HAS 4 BRAND NEW TYRES (4000KMS OLD)
18IN RIMS BIG DISH ON REAR
DARK TINT
Price:
$15000
GOLD COAST, QUEENSLAND
Contact: PM, Reply or call 0408992232 RUSSELL
I can vouch for this car being a serious fast car enthusiast myself . I have been in it on many occasions and i would have bought it by now if i didn't live overseas most of the year. Its such a quick, clean running, smooth and super responsive car. It feels like its on rails!
G
 Share
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
