Item Summary: 1998 Audi A4 1.8L Turbo
Condition: Excellent
Reason for Selling: Moving on, looking for a more practical car!
Asking Price: $25,000 ono
Delivery Methods: Pickup
Contact Info: PM on here
Extra Information:
Photos are from my Hot4s shoot which was published in Issue 201 (Jan 2011 issue). See issue for full spec listing
Brief rundown on the car:
* Car has been resprayed in House Of Kolor Candy Marble Red to Jet Black Fade by Queen Street Customs
* Interior is black leather with Gucci Fabric Inserts, Black vinyl roof with downlights, done by Queen Street Customs
* Custom Stereo install retrimmed in Black Vinyl and Gucci Fabric
* Motor is completely standard, regularly service, major service was carried out on vehicle at 120,000kms.
* Engine accessories are only a turbosmart boost tap (running 10psi) with turbosmart type 2 bov
* Stainless steel exhaust tips added, however exhaust system is completely standard
* Car has been dynoed @ Autosalon, making 87.4kws at the front wheels
* Stereo has had a DB reading of 131.3db @ Autosalon Final Battle 2010
* Bonnet has a couple of stone chips in it from driving it, this car is not a show pony, it gets driven most weekends along with the occasional trip to work. Car is always garaged at home and at work (if driven to work)
* Rego till May 2011
* Only thing is that the clutch will need to be replaced in the near future.
* WILLING TO DISCUSS SWAP OFFERS (I am after a Peanut eye (2003-2005) Subaru WRX)
* PLATES DO NOT COME WITH THE CAR
SERIOUS OFFERS ONLY...NO TYREKICKERS!!!!!!
Few photos of the car (will post larger size ones soon)
https://www.sau.com.au/forums/topic/349372-fs-1998-audi-a4/
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
