Nissan Fuga And Toyota Crown
why are Nissan and Toyota Australia not importing these nice car's to Australia
i can answer this, at least for nissan.
i went over to japan with nissan and we spoke to the big mugs at nissan and asked why their larger range of fcars were not being brought to our shores.
they said it was to much drama to worry about.
we asked why are we not able to try them out and push for a better nissan in aus.
they said basically we had trouble before.. they explaned to us that the ENTIRE stock for Aus in one year can be manufactured in ONE DAY. just to illustrate how unimportant our marke was. if we were too hard to deal with they would drop the AUS market and just take a day off :P
Would love to be the first to have a 450GT Fuga, but i wouldn't be able to finance it for atleast another six months, will deffinatly contact you Iron Chef if I am still interested when the time comes around. Also do they do the 450GT in the latest shape or not? because that would be what I am after. And what sort of money do you think??
No they don't - as part of Nissan's official turning ghey process, they dropped the 450GT and released a 370GT Hybrid. They run 2.5 or 3.7 VQ motors, same as the V36.
If you wanted the current shape, I doubt you'd see change out of $50K, that's without looking too closely at values though.
Would it be worth bothering with the Fuga?
Real nice car but Infinity are starting up in a few months in Aus and the "M" series is in the lineup (Infinity labelling of the Fuga line).
I don't think they are releasing the M45 initially though...
See above regarding the M45, although the Fuga gets the VK56 in the US so fingers crossed we get it too. No V8 on the Japanese market means problems for importing them.
Edit: Just checked Infiniti UK - no V8 being sold there either, so they may not have engineered the VK56 for RHD markets, which would explain why they're not on the list to be sold here in the short term.
When I listed the original Fuga on SEVS, it didn't make financial sense at the time, but it makes VERY good sense now. If Infiniti bring out the M here officially, it will also make good sense if they can be imported for half the price Infiniti are charging ;)
Well the M infiniti will cost around the 100k mark
Maybe a little less - think BMW 5 series prices.
Yeah, but if they are locally delivered (yes, different name but same car/same manufacturer) then I don't think they will be eligible?
They will be eligible up until they're sold here locally. Same with the G series - the V36 Skylines will be eligible until the Infiniti G is released, bringing a very long era to an end for Skyline imports.
Older models should still be eligible?
See above.
^^^Completely correct. Australia is an irrelevance in most cases for Nissan Japan. Our ADRs are a real pain in the arse, which is the reason why manufacturers have been pushing so hard for us to align our rules to Europe. Making a unique spec for such a small market is a right pain in the arse for manufacturers.
Guess I better get my ass in to gear if I want one then, and i don't mind the old shape either just need to be rid of that grille, what sort of figures for a nice low km's 05-07 model 450GT do you think Chef?
 Share
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
