Hi guys,
I picked up a GTR a couple of days ago and everything seemed fine, it drives very well and boost builds from ~2000rpm and will hold at ~7.5psi all the way from 3k odd to redline.
Felt pretty gutless and thought it was a bit down on power but put it down to the hot weather and the cars bolt ons being pretty sedate (just dump pipes, hiflow cat, cat back and pod filters).
Gtech+Iphone confirmed my arse dyno predictions, apparently making between 150-170kw at the wheels which is a bit of a worry so I went to see how much it would make with 1 bar and the restrictor on the solenoid line is already missing!
I cant find any boost or vacuum leaks, but it absolutes refuses to make over 7psi. Aside from the power and boost the car runs perfectly and cleanly.
I'm hoping the solenoid is f**ked or the cat is clogged up and the workshops I want to go to are still closed from the xmas break.
TLDR version:
Car is running 7psi with boost restrictor removed and making underwhelming power with no other symptoms.
Any suggestions I can easily check?
https://www.sau.com.au/forums/topic/349395-gtr-power-boost-loss-suggestions/
Hi guys,
TLDR version:
Have the exact same problem with the same mods. Was making 154kw at 7psi and starting to detonate. Willall stopped the run. Was just on the dyno to get a power reading before an ebc install but have a Mines ECU installed (came like that from Japan last year). Didn't fix the problem because I was only gonna wind it up before doing my turbo swap so I started my turbo swap earlier.
Keen to see what your problem seems to be.
check wastegate / actuator operation
if the gates are held open, the car will be sluggish, lack power, make some levels of boost (low) and wont blow smoke etc, but will be sluggish
check the actuator signal, where does that vac line run to? and check actuator operation, does it open? is it stuck open?
Boost hasn't changed at all, however I took note of when it comes on boost and it around 1800rpm in 3rd it starts building boost. Full boost around 2700rpm.
Stuck wastegate would not have this much low end in my opinion
Ambient temps have gone from 35 to 20 degrees yet my power output dropped to 160kw atw on the first test.
Second run noticed it started to lose a bit of power the longer I let it stretch is legs.
Put 1+1 together and immediately stopped.
Sounds like lean condition / fueling issue plus a separate boost issue.
Have a suss what ECU its running, probably a Mines or similiar.
open the ECU up and see if its been chipped, I know my rb20 had a mines chip in the ECU, advanced the timing massively and was way too rich, basically was running on the knock map permanently and very rich, resulted in worse than stock performance.
  • Like 1
Factory nissan seals still intact on the ECU so I assume it hasn't been opened. Is it possible to open it without damaging the seal, and if so would someone really bother?
Its going back to the beginning but you have checked all the basic things like air and fuel filters? It might also be worth a look at the front of the cat just so you can rule that out but if it doesnt drop off its probably ok. Also that much power at that boost is a little low but not way down. If everything else looks ok i would be checking the vacuum lines and making sure its not seeing straight manifold pressure at the actuators. If a waste gate was stuck open it would be alot laggier than that.
Good luck
HI Guys,
Im in similar situation, probably worse.
Just picked R32 GTR from Japan.The car is immacutlate condition,the engine bay is pristine and looks like timing belts were done recently.
I can see actuators have been chaged to hks units and rstrictor removed from solonoid.
The Car starts and idles normai and revs freely, but its like driving a natuarlly aspirated car, There is litlle or no boost coming.
intercooling piping has been checked and there seems to be no leaks.There is no smoke coming from exhaust .The only thing i can find out of the ordinary in the engine bay is what looks like a vac pip that been blocked.
off that comes from somewhere under the inlet manifold
what do you guys think, are why turbos gone ?
I had similar problem with my 33 GTR. Would go into limp mode and reduce the boost km standard. Turned out to be the factory ecu. If you can get hold of a fc plug it in and see if the problem goes.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
