I want to lower my car and inch all round, for a lower centre of gravity and better look as part of a series of upgrades.
The speed for sale website shows a whole range of the usual brands that have a similar number of coils and weight to the OEM springs.
But then I saw the 'Swift GTR Sport Springs' lower down the list, that seem to have a whole lot of benefits over the normal type. They us a higher grade steel and have almost half the coils and weight?
What do you guys think?
I want to order a set ASAP, so some past experience advice from members would be appreciated!
https://www.sau.com.au/forums/topic/349398-lowering-gtr/
I have a set sitting in my garage that I haven't put on yet. As far as I know they are the only true 1inch drop all round spring. They also make comfort mode actually work. You might find it hard to believe but I actually bought my set from Nissan and then brought them back in my luggage.
https://www.sau.com.au/forums/topic/349398-lowering-gtr/#findComment-5613908
g35me
When you say you brought them back in your luggage, do you mean from Japan?
Did you get a stock item number?
Could be worth a shot hitting my local dealer if they have a Nissan stock number, you never know your luck.
Also, what did they cost you in AUD.
Thanks for the info.
https://www.sau.com.au/forums/topic/349398-lowering-gtr/#findComment-5615084
I bought them from Fontana Nissan which is about 1hr drive from Los Angeles. Unlike in Australia you can purchase aftermarket gear from other manufacturers direct from the Nissan dealership. Follow this link for all the details:
http://www.nagtroc.org/forums/index.php?showtopic=44863&hl=
https://www.sau.com.au/forums/topic/349398-lowering-gtr/#findComment-5616152
  • 1 month later...
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
