Hey Guys up for sale i have,
3.5 inch 5zigen exhaust only used for three mounths, still in very good condition, like new. This is a good performance exhuast which isnt too loud but has a great tone.
$300
r33 gtst manual radiator still in very good condition
$100
r33 gtst series 2 coilpacks, no cracks and still work 100%
$100
r33 gtst stock intercooler in good condition
$50
r33 gtst intercooler piping
$100
r33 veilside spoiler needs a respray
$100
pod filter
$10
pod filter
$10
tomei fuel pressure reg, like new works 100%
$200
HKS evc-s boost controler like new works 100%
$350
r33 gtst dump pipe from ebay
$60
r33 gtst stock exhaust manifold in good condition no cracks
$70
r33 gts automatic computer and ecu
$100
r33 gtst stock fuel pump works 100%
$50
r33 gtst harmonic ballancer good condition
$20
r33 gtst stock alternator working condition
$80
r33 gtst stock cooler pipe with stock BOV
$50
if you have any questions or are interested txt or call me on 0405 422 600, located in melbourne vic.
https://www.sau.com.au/forums/topic/349428-r33-parts-for-sale/
