Hi all,
I as a Red P-Plater was pulled over and fined for illegal window tint and not displaying my p plates correctly as a result of the window tint.
So now im looking at 119 and 299 out of pocket, along with some demerit points, 3 to be exact for something that should have been picked up by the RWC.
Shouldnt i have been told prior to registering the vehicle in Australia that my windows were to dark?
Am i right in saying that my rear windows on my R34 Sedan are darkened factory glass along with my rear window, so getting that removed will only just kill my bank account?
Thoughts?
As long as u didnt tint the front ones lower than 35% and the rear is factory privacy glass than its stock = not illegal. You just have to prove its stock. My 350GT has rear window and back quarters as stock privacy glass and cop has not pulled me up. As for P plate being not displayed correctly they have you there...
Hi all,
Thoughts?
Since now i must ask for a review, how would i go about proving its stock?
I have no clue as to how i prove that in a letter.
In QLD no window can be less the 35% as far as i know... it is stated in the Mod hand book also... LINK PDF ( this i am sure is not 100% right as it used to only be the fronts... (eg. Limos))
pdf_modification_motor_vehicles21.pdf
If you like many others place a white and red sign behind a window you can almost not see through and get find because you can't clearly see the p plate, then you deserve to get the fine.
Dark rear tint is legal (well used to be till i read the mod book), but displaying your p plates though it so the can't be seen well that is not my friend...
Edited by 99 GTT
Just researched this in vic as I just got my windows tinted, it states in a pdf on vic roads website that no window used to see other traffic is allowed to be darker than legal, only circumstances given where it is legal is bus's where the rear side windows are not used by the driver, as for the rwc, I'm sure they should have picked it up, how long ago was it done?
When he defected you did he test it or just say it is too dark?
i understand the incorrect display of the P plate will not be overturned but i am though concerned about proving the legality of the tint.
Although i do find it fustrating that the car was in my brothers possession for 3 years before i bought it and he was pulled over for breath tests and never once questioned about the visability of his P plates.
I will have to ensure i display my P plates on the outside and retrieve my two roadworthy certificates from first registering in Aus, then handing over into my name from my brothers and see if that can get me anywhere.
Edited by yesitshim
The Roadworthys include one done only 2 months ago
and i wasnt tested, only told too dark.
Thankyou to everyone who has posted the tint laws, they have certainly helped!
Is there a tint company sticker on it somewhere? if not call around a few places to see if they have the tools to test it before you rip it off.
Initially i tried to get it removed, until i was told it is in fact darkened glass.
In SA, the tinting laws have provision for things like factory privacy glass - it's on plenty of cars, not just skylines - and its typically allowed to be much lower than the regular 35%.. (R34's is like 18% or something)
When I had a regency defect inspection the inspector checked the glass, saw it was factory privacy glass and let it through - surely vic inspectors aren't that retarded? I know my car has a sticker on it somewhere about 'UV glass' or something... maybe that helps?
Either way, what state are your front windows in - 35% or lighter?
You're not going to get out of not displaying your P's properly - it's your responsibility to ensure they're visible, however if you got fined for the *tint* specifically, then you should be able to get out of that (assuming your fronts are legal).
as someone said above, a RWC isn't a check of the cars legality. at least in QLD it is no longer actually called a RWC but a safety inspection, and if you are driving a car with illegal mods it isn't up to the inspector to point these out to you. he only has to check certain aspects of the vehicle and pass it on those grounds. if the illegal mods aren't in one of those aspects then it will pass, but you can still get fined for it.
also just because the tint/privacy glass is stock doesn't mean that it is legal either. you have to remember that the skylines (other than certain r32 GTRs) aren't an ADM car, so if a compliance workshop did a dodgy job and didn't remove the tint when they should have then that doesn't mean it is legal.
That does help, especially since it is factory privacy glass.
I do have the exact sticker and my front windows arent tinted they are just normal, yeah 119 isnt my concern, ive learnt i cant put my P plates up on the inside.
thanks.
I'm %99 sure in Vic the rear window can be as dark as %5? As it's the same circumstance as a ute having a toolbox mounted in the back that blocks the rear window...
For SA (I know you're not in SA, but maybe VIC has similar documentation?):
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/MR430_Window_Tinting.pdf
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/430_Window_Tinting_for_your_Motor_Vehicle.pdf
.. these specifically mention 'body tinting' - factory tinted privacy glass.
Another more generic link:
http://www.wfaanz.org.au/AutoAU.htm
-- which specifically states
Vehicles with factory tinted glass may have lower than 35% VLT. In these instances, each window is marked as AS3 glass.
  • Like 1
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
