cracked open a std nissan filter a while ago and honestly was surprised with it, after a lot of feedback was always to use the Nissan filters becasue they were better i thought i would cut open the next filter i buy and check out the differences between the two.
Here is some photos between the Ryco and the Nissan filter, personally i like the closer pleats and metal vs fibre ends(yes i know they are different sized filters).
I had to put a screwdriver through the ryco filter to get it off the car so you can see some of the damage it has caused.
On the right is the nissan one vs the ryco on the left
Nissan End of filter with anti drain back seal
Ryco end of filter,
The two compared together
my hack job and the springs, the Ryco uses a spring and the nissan a flexable plate, i like the nissan better in this instance.
The fibrous ends on the nissan filter
Ryco end
Interested to see what other people have cut open (in australia not on the interweb from overseas) and discussed above.
https://www.sau.com.au/forums/topic/349444-nissan-filters-vs-ryco/
the ryco seems to have tighter pleats and be better constructed with the general look and feel being better then the Nissan filter.
It made me worry with the fiberous ends on the nissan flter if they were to break off as well rather then the metal on the ryco.
personally i think a lot of it comes from a mix of misguided information, and people being what i like to call brand whores. as well as a lot of import owners thinking their car is something it isn't. the majority of imports (including skylines) are just ordinary cars. there isn't nothing mystical them. the majority of owner of them in japan were probably just family type people who bought them because they thought they looked nice and went ok (the same reason why someone here might buy a commodore or a falcon or even something like a lancer). half of them probably weren't even serviced regularly. then they get bought buy some young enthusiast in australia who thinke they are some spectacular road going race car and that they need to be treated differently to any other car that has ever been made.
ryco filters would be used on probably hundreds of thousands of cars on australian roads. they are probably regarded as the industry standard of the non-genuine filters.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
