cracked open a std nissan filter a while ago and honestly was surprised with it, after a lot of feedback was always to use the Nissan filters becasue they were better i thought i would cut open the next filter i buy and check out the differences between the two.
Here is some photos between the Ryco and the Nissan filter, personally i like the closer pleats and metal vs fibre ends(yes i know they are different sized filters).
I had to put a screwdriver through the ryco filter to get it off the car so you can see some of the damage it has caused.
On the right is the nissan one vs the ryco on the left
Nissan End of filter with anti drain back seal
Ryco end of filter,
The two compared together
my hack job and the springs, the Ryco uses a spring and the nissan a flexable plate, i like the nissan better in this instance.
The fibrous ends on the nissan filter
Ryco end
Interested to see what other people have cut open (in australia not on the interweb from overseas) and discussed above.
https://www.sau.com.au/forums/topic/349444-nissan-filters-vs-ryco/
the ryco seems to have tighter pleats and be better constructed with the general look and feel being better then the Nissan filter.
It made me worry with the fiberous ends on the nissan flter if they were to break off as well rather then the metal on the ryco.
personally i think a lot of it comes from a mix of misguided information, and people being what i like to call brand whores. as well as a lot of import owners thinking their car is something it isn't. the majority of imports (including skylines) are just ordinary cars. there isn't nothing mystical them. the majority of owner of them in japan were probably just family type people who bought them because they thought they looked nice and went ok (the same reason why someone here might buy a commodore or a falcon or even something like a lancer). half of them probably weren't even serviced regularly. then they get bought buy some young enthusiast in australia who thinke they are some spectacular road going race car and that they need to be treated differently to any other car that has ever been made.
ryco filters would be used on probably hundreds of thousands of cars on australian roads. they are probably regarded as the industry standard of the non-genuine filters.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
