  On 08/01/2011 at 5:37 PM, HYPED6 said:
Here is my little story. I have been wondering the same thing the last 6 months or so. This is what I have found.
I bought my gtr with plain bearing -5's. Now with
Cams, 10.25 @ 292
Good after market front mount
Very good fuel
Stock dumps
Stock but ported exhaust manifolds
After market exhaust
After market ECU
Fuel systems to support anything I threw at it
Made around 490 rwhp on around 20 psi. Boost control was rubbish. Needed one solenoid per turbo and a 32x32 table just to get any descent control.
If I rung its neck.... (shut the wastegates) it would spike to 2 bar as it came on to boost and 22 psi at 850rpm it would make 530 rwhp. Rubbish.
Now I thought that this was under powered. So made some 2.5inch dumps. No difference
Shortly after one turbo died.
I bought some shiny new -10's.
Made some 3 inch dump pipes. Twin 3 inch front pipe to single 4 inch system.
Engine now makes 400rwhp on 10psi. Much better :)
Bloody thing hits another brick wall at 480 rwhp!!!! Regardless of boost levels. Regardless of ignition timing or fueling etc.
Now. I believe its the standard exhaust manifolds. I really do believe that is the key to making big power out of these turbos.
At the moment I am currently fitting a single turbo charger. Its the only thing I am changing so it will be a reasonable back to back.
Has any one else seen anything else similar?
When my car was on the dyno a few weeks ago we went from 1.7 to 2.0 bar. I made an extra 12 kw (414rwkw) or something stupid so we pegged it back to 1.7 bar. I think my exhuast is too small but also I reckon my head port doesnt match my setup. Its a little lethargic down low but doesnt make mega numbers up top.
Are manifolds stock or port matched. N1GTR's manifolds are standard and makes more power then that.
Those 292 cams are bloody MASSIVE!
Cams, 10.25 @ 292
Very good fuel
Stock dumps
Do not just keep throwing money at it. Find a real mechanic if you cannot get the thing to work.
You have not mentioned anything about the motor itself. What sort of head work do you have to support 292x10.25 cams and what sort of motor have you got that would do the 10,000rpm those cams imply?
If the answer is none you have some major issues. I am horrified of the thought of this thing.. I would personally put pencil to paper and plot exactly what I want from it and the setup I anticipate will get me there. I would then pull the motor out and strip it back to a long motor, refitting only parts that suit what I have set out to plan.
No number of band aids, double sided tape, sikaflex or zip ties will stop cut wrists from bleeding out. Get onto a real fix, maybe even start your own thread in the members ride section to properly introduce yourself and the car so you may start an active discussion to help your cause.
It honestly does sound like you have a hungry money pit, see below.
Gav how long have you had your Tomei manifolds on your car? I have been through two sets. Cracks, holes blown in runners and the last set didnt make it to 2000 kms. Alot of that was on E85 (second set) too.
I'd be having a good look at your tune, and your EGT's. These manifolds shouldnt crack if your tune was correct for normal unleadded fuels.
While switching to an alcohol based fuel in theory lowers combustion temps and EGT's, the way many people are setting up their E85 engines with higher compression means the common target afr charts dont produce an EGT that is in the safe range. Ive heard stories of melted exhaust valve guides in alcohol based fuel engines that run compression at the higher end of the scale, so it stands to reason that a moderate increase in EGT's could certainly cause stress cracks in in a manifold.
  On 09/01/2011 at 1:30 AM, Tangles said:
an amazing difference in midrange!
Damn right it is. If you look up the hot side of the turbo's they are exactly the same.
Gav, were the turbo's modified in anyway or were they straight out of the box and bolted up?
  On 08/01/2011 at 10:55 PM, rockabilly said:
so the graph only goes to 6500 rpm?.
6800rpm by the calculations... But I do believe Gav runs 4.3's so would be more along the lines on 7200rpm
Edited by SimonR32
Thats a good point. My engine is 9.0:1 comp so it is highish. Next time I go back I might mention it to Yavuz (the tuner) and see what he reckons? Either way im back on ported stockers.
Actually, I'm not overly impressed with the Tomei manifolds for that reason. I had cracks in the first set that I had welded. Then I found they had burn't through on the outside of the runners. I'm on my second set now and if these fail I'm going back to cast iron units.
On the graph I posted, I did forget to mention I'm running GTS-4 ratios. I'll track down an updated E85 dump graph showing the other set-ups with RPM on the X axis.
  On 09/01/2011 at 9:37 AM, R31Nismoid said:
Ah already done...
Notice any difference?
It could be placebo but it feels like there is. But that could be just my head. I want to get another set and extrude hone them and really get it spot on! So many people swear by the stockers.... and going by Gav's post above me he has had issues with the Tomei's aswell!
  On 08/01/2011 at 9:04 PM, paulr33 said:
RPM = (SPEED / 28) * 1000
to work out RPM from a speed based dyno plot, assumes 4th gear with 4.11 diff gears
This doesnt really work for mine, as I doubt my car makes 340rwhp @ 6250rpm. Its more like 7250rpm. Hmmmm.
Leave the things alone
  On 11/01/2011 at 10:13 AM, Piggaz said:
Gav, were your -5's straight out of the box or were the tinkered with?
With the exception of HKS actuators they are bog stock.
These did need a freshen up with seals and other bits and pieces (maybe bearings) recently after around 5,000 km of mainly hard track time. Still have the same exhaust and compressor wheels 'tho.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
