Is that a raised deck OS30 or hi-deck rb28, or an RB30 ? The cam covers look suspisious close to the strut tower brace.
The comment made about RB29's Vcam setup in that thead seemed to indicate a custom v-cam system, not a hks kit? Having never seen it though I can only go on what other misinformation is out there...
Like the rumor that Paul of Red-R racing is developing a vcam style arrangement...
Correct, it was not the HKS version.
Dont HKS have 3 different cam profiles? Which one would be the ideal one for a -5 setup?
Matt has the smallest version.... But then HKS recommend for a RS/TO4Z setup the biggest duration and lift setup in the V-Cam they half....
Nope its a HKS 2.8.
Probably just the angle of the photo I took.
I know the owner of the car in Japan and he has mint 32,33,this 34 and another and a 35.
Too much coin !!
well....i am at the moment removing my rear housing from my gt4094r and sending it to the states to have a different type of quick spool valve machined into it. check the quick spool valve thread on here for pics..ifi dont like that then will sell and deffo fit twin 2860,s ....
Ill go from the start
Nismo AFM's
ARC Duel entry 105 mm cooler
Nismo plenum
Ported factory manifolds
GT RS's
HKS split dumps
HKS Front pipes (twin 70 mm into 85 mm)
3.5 'cat'
Kakimoto Full mega N1 catback.
hey paul - i finally read your thread & there is a lot information & opinions in here...
my setup is similar although i have:
stock intake plenum
-10 turbos (apparently dont makes as much as power as hks items lol)
xforce dumps
hks super drager exhaust (steps from 3.25", 3.5" then 3.75" at the rear diff)
z32 afms
100mm hks exhaust
ported exhaust manifolds
3ltr bottom end (wont necessarily give you more peak power, torque yes)
...the only thing i could pick which ive raised with you in the past & DOES make a massive difference: is your head ported? this will give you up to 50awkw gain when you are playing in the 400kw range (as confirmed by worksops i use)
i personally wouldn't go changing dumps & exhaust as mine is similar & makes 405awkw (450rwkw) @ 23psi. you want more midrange so yes go with -5s BUT before u do that, pick the brain of that other dyno tuner that i suggested (name disclosed as im not here to sledge workshops).
going to smaller cams - no way! ive had this discussion with crd, red r racing & rips racing many times - unless these workshops dont know what they're talking about & smoke bongs, leave your cams in there (im running 280's @ 10.5mm lift)
work with what you have otherwise your gtr will is going to send you broke (like the most of us lol)
go forth :)
stock intake plenum
xforce dumps
z32 afms
100mm hks exhaust
go forth :)
Marko,
Head is ported.... how good of a job is anyones guess. Does it match the turbo's and cams? I have NFI
Cams as Ash has said a very touchy subject.
Tangomatt used baby cams (Ok he had vcam but meh)
Marcus used 264's @ 9.7 and got a mega result
I am using 270's @ 10.25 and it comes on later and makes less grunt.
Gav is using 272's (i think)
Ah we could go back and forth about this.
I also use 264 9.7
15psi @4000rpm made 489rwkw on E85 @ 1.8bar GTRS's
side pipes 3" x2
8.55:1
89mm bore
Another motor we built
more head porting than mine
BP98 with 10% methanol
264 9.7 15psi@3600rpm
614kw at the engine 22psi
-10's
side pipes 3" x2
8.7:1
89mm bore
Edited by BoostdR
I actually feel -10s will flow more. The anti-surge comp cover reduces efficiency to bring boost on slower to reduce surge. For a 3ltr I would go the garretts.
As for cams we went with what works. Used to use JUN 272's and ordered 264 by mistake. The results were more power everywhere. For under 400kw I would go mines shorepro. 252 10mm or whatever they are.....
I had the Gibson cams dialed. I can't remember exactley what they were. Something like 278 292 10.5 staggered but I think that wasn't at advertised duration. Will have to dig up the sheet for you guys. Base circle was 1mm under aswell.
I was looking at the 260's @ 10.8mm. Thoughts?
The Gibson cams are HUUGE. I wonder why they went for such huge duration?
gibson used big cams because they work - unless gibson was smoking the same stuff as jim souvas & rob ward :)
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
