$6500 reasonably firm
No RWC - no time and car is cheap for what it has
Rego expires 19 Jan. If renewed i will increase the price accordingly
on carsales also
1996 Stagea DAYZ Edition
Factory DAYZ body kit
Twin sunroof
Cargo net
Cargo blind
Alarm
DVD player
3in stainless steel exhaust from turbo to mid muffler, lukey stainless mid muffler, custom from mid muffler back.
Front Mount Intercooler
Hypergear high-flow turbo Under 8,00kms as it was done the same day as suspension.
Apexi SAFC - tuned for economy
Manual Boost Controller (set at 8psi)
New coil packs approximately 1100kms ago
New oxygen O2 sensor approximately 1100kms ago
Blistein suspension installed under 8,000kms on the front. Rears are still brand new and not on the car.
Serviced approximately every 7,500kms using motul oils. Last service was approx 1,100kms ago.
179,434 KMs - we purchased the car with 101,000kms in Jan 2006. major service (timing belt etc) was done by previous owner as part of the sale. Very meticulous previous owner hence why we bought it.
The only thing that has ever gone wrong with the car was the starter motor which I had reconditioned mid last year.
Things to know:
Clear on the spoiler has faded
Front brakes are coming due for replacement
Have 18inch GT-O5 wheels not on the car at the moment but will come with the car - one wheel has a buckle due to a pot hole
Questions please ask.
Fabulous car which after 5 yrs is still a joy to drive. We are only selling because our 7yr old is getting a bit squashed now between 2 baby seats otherwise it would not be going anywhere.
PM Me or email [email protected]
thanks
Ian
https://www.sau.com.au/forums/topic/349477-fs-vic-1996-nissan-stagea-rs4/
  • 3 weeks later...
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
