Haxorz Posted January 7, 2011 Share Posted January 7, 2011 Everytime I start my V36 it pops up with a warning message in Japanese. A friend who can read some tells me it's something about Engine Oil, presumably 'please change it'. My car came into the country with 10,000kms on the clock and I assume a full oil change was done during compliance. It's done 16,000kms now. I also know in the menus there is a setting where you can adjust the service intervals and all that. Does anyone know if this warning appears due to sensors in the car, i.e. it can tell the oil needs changing, or is it something that service guys manually reset during a service (which they neglected to do, fair enough being all in Jap). Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/ Share on other sites More sharing options...
Haxorz Posted January 7, 2011 Author Share Posted January 7, 2011 For the benefit of the forum - just spoke to my compliance guy. He said they do use a fully synthetic oil, and it is most likely just a manual reset thing based on the ODO. Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-5614644 Share on other sites More sharing options...
SyKRyD Posted January 8, 2011 Share Posted January 8, 2011 it's manually set. you can set it yourself inside one of the menu options. check loz's jap translation sticky Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-5615915 Share on other sites More sharing options...
180 wanabe Posted January 9, 2011 Share Posted January 9, 2011 A friend who can read some tells me it's something about Engine Oil, presumably 'please change it'. My car came into the country with 10,000kms on the clock and I assume a full oil change was done during compliance. It's done 16,000kms now. I hope your compliance workshop actually changed the oil.... Im pretty sure that the one who did my car didint drop the oil Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-5616936 Share on other sites More sharing options...
M34N Posted January 9, 2011 Share Posted January 9, 2011 I hope your compliance workshop actually changed the oil.... Im pretty sure that the one who did my car didint drop the oil Yep I had doubts on whether the compliance shop did change the oil in my V36 as well, so I just changed it since I've done just under 5,000km in it myself in the last 4 months. Figured I'd rather be safe than sorry, got some Mobil 1 5W-30 and changed it myself, along with a new K&N HP-1008 oil filter, all up around $120. At least now I have peace-of-mind. Would you trust the compliance shop? Do you know them personally? My advice would be to just change it if you're unsure, or just get your mechanic to do it. I would say most compliance shops are genuine and would have done their job properly, but why take the risk? For the sake of $120, I'd rather just change it and not find out the hard way they didn't change it! Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-5617244 Share on other sites More sharing options...
sikv36 Posted February 13, 2012 Share Posted February 13, 2012 Is this the warning Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6232802 Share on other sites More sharing options...
Wogboy Posted February 15, 2012 Share Posted February 15, 2012 Like mentioned earlier, it can be changed in the menu. I've turned mine off. Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6236776 Share on other sites More sharing options...
hodgoau Posted July 16, 2013 Share Posted July 16, 2013 i have that warning message on mine. What is it? Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6929731 Share on other sites More sharing options...
awsam Posted July 19, 2013 Share Posted July 19, 2013 I have the same warning every time I start mine. There's 2, slightly different characters. No idea what it means, there's no other warnings. Does anyone know what it says? Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6934986 Share on other sites More sharing options...
PN-Mad Posted July 19, 2013 Share Posted July 19, 2013 Did you guys read the thread....? it's manually set. you can set it yourself inside one of the menu options. check loz's jap translation sticky If its like the v35 then it has engine oil, engine oil filter, air filter, and something else I can't remember. It is manually set for xkms. Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6934999 Share on other sites More sharing options...
awsam Posted July 19, 2013 Share Posted July 19, 2013 (edited) Using CamDictionary for Android, that error message posted above says "Oil filter - set distance has been reached, press maintanance button" f**king technology, insane! My second error reads "Engine oil - set distance has been reached. Press the switch information, maintanance. You can set information you chose" Guess I'm due for a service! Edited July 19, 2013 by awsam Link to comment https://www.sau.com.au/forums/topic/349488-change-engine-oil-warning-v36/#findComment-6935080 Share on other sites More sharing options...
