who has a microtech LT-12
What is base timing for R33 series 2 - isn't it 20deg measured at idle?
Could you take a look at the log of timing position and tell me what your idle ignition timing is set at?
I read that the timing is meant to be 20deg in idle in neutral on the standard computer? Shouldn't it be the same on LT-12?
On the microtech data logging screen, mine reads 10deg at idle in neutral.
Is this indicative of incorrect base timing?
Also isn't the TPS supposed to go all the way to 100% - mine only goes to 99% and I wonder if this could be the cause of a lack of extra kickdown when the pedal hits the metal for the auto trans.
Does TPS wire go directly to the auto box? (don't have a w/shop manual to check)
Could calibration of the TPS have to be done specially for the auto subcomp as well? Maybe this is the reason that while the auto box works it doesn't work quite as well.
Would any of this cause my fuel economy to be like this:
22L/100km when gentle driving for tank
and
16L/100km when I hammer it for a full tank.
Also something else prominent - when I hit 7000 rpm and let go the accelerator, it stalls.
Your fuel consumption sounds like it hasnt been mapped at low load and cruise throttle.
I had a similar problem to you, I had AFRs in the low 11s for cruise (60 - 120kph) and better economy on boost where it was in the 12s - get the car on a dyno to check for sure.
Base timing for S1 R33 is 15deg
base timing for S2 R33 is 20deg though isn't it?
regardless isn't the microtech supposed to read higher than 10deg at idle then?
What I'm asking is - am I correct in assuming that you measure base timing at idle and that the microtech should show the same on its readings?
I'm may have to get it retuned with the base timing advanced?
I've asked someone and the only way you can know the base timing is to look at it on the engine. It is just a little hard to start and with readings of 10deg on initial start and idle it seems suspect to me.
666DAN - I will find out exactly once I have it rutuned full matrix mode. For 12.0 on full boost and 14.5 off boost. This should fix my fuel economy.
A lot of timing lights will show up double the actual timing. I went to set mine to 15 degrees, and it showed up as 30. Which is lucky, because that's where the last mark is on the pulley. If you want to set yours to 20 and your timing light also shows double, you might have to make your own marks.
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
