Hi everyone,
Looking for some advice.
I have an R33 GTS25T with:
Pod filter
Intercooler
3 inch turbo back exhaust
Walbro fuel pump (not a fake)
550cc injectors
Oil catch can
HKS GT-RS Turbo
Power FC
Greddy profec bspec 2
Currently it makes 338rwhp on ~15psi. No real blowby to speak of, pretty healthy motor on 97xxx kms.
Basically, I was considering getting a retune and upping the boost to around 18psi. Anyone know what sort of gains I could expect, or should I not bother because I am already making the power most people make out of this turbo anyway? (Boost being a measure of resistance to flow etc etc)
I have also heard claims that the standard exhaust manifold is marginal even at the power I am currently making, is there any truth to this?
Cheers :)
https://www.sau.com.au/forums/topic/349514-gt-rs-more-boost/
Used to run 20-21psi all day every day for over a year with no dramas (currently running low boost until I tune it for high boost again).
Chuck it on a dyno and see if there is gains to be had. If the gains are marginal than turn it back down.
Mine used to make a lot more power on 18+psi than 14psi, but every car is different.
1. unless you built the motor or know the person that did then it's not on 97,000 (probably more like 197,000)
2. do it
You know this how? :P
Thanks mate, can you remember any numbers, like the difference between 14 and 18? Plus, from the all important seat of the pants dyno, was it worth it?
all these people with "80,000" skylines make me lol
as phil said, throw it on the rollers and tune it up until the point of diminishing return
230-235rwkw on 14psi and 255rwkw on 18-20psi prior to any head work.
Once the headwork was done the most I saw was 263rwkw on the same dyno on 19-20psi.
Always had the boost start dropping off towards redline though. My tuner didn't really know how to tune the boost controller so my boost curve was fairly average.
At the moment I have retuned it on low boost and the car feels slow as hell, so yeah definetely high boost all the way lol.
However remember every single dyno is different. I've seen cars with dyno sheets saying 350rwkw and then they run it on a different dyno and it will be 310rwkw. It really does vary so I try not to use other peoples dyno sheets to much other than a guide, and just use the same dyno every time you do mods to see if there is an increase on that particular dyno.
Yeah, I was more interested in the hp gain vs boost added, that helps!
Are you running a standard exhaust manifold?
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
