hey guys and girls,
anyone had an alignment on there c34 recently and want to share the specs,
ive looked high and low for the specs but cant find anything, suspension is standard apart from being 50mm lower,
looking for 4 wheel specs!!
share please people!!
thanks
https://www.sau.com.au/forums/topic/349543-wheel-alignment/
Don't suppose anybody has the specs for the M35 handy?
Where are you located?
I don't have specs (forgot to ask) but Wholesale Suspension in Penrith 02 4721 2187 did mine, I'm sure they'll be able to help.
https://www.sau.com.au/forums/topic/349543-wheel-alignment/#findComment-5615762
Wheel alignment specs. You won't be able to get as much castor as me without a/market arms so just get as much as possible on left and then 1/4 deg less on right.
i got to do a wheel alignment with Glide (recommend in perth) when my swaybars and some second hand nismo camber arms go on the stagea nxt week, imo buy cusco or some that are strong and of decent quality, not cheap ebay items. :thumbsup: with sensible wheel sizing and 50mm lowering it will be easy.
Edited by dirtyRS4
https://www.sau.com.au/forums/topic/349543-wheel-alignment/#findComment-5616884
i did my own alignment at work on a 4wheel aligner. my C34 is SKY HIGH, can fit my fist above the tyre front and rear yet it still had 2* neg camber on rh rear and 2*35' neg camber on lh rear. i got them both about .25* lower with the eccentric adjuster but it clearly needs the aftermarket arm with tie rod style adjusters (13deg of ajustment? instead of .50* with the standard ecc bolts). it was also toe-ing out overall front and rear and given the negative camber it explains why the tyres i got it with were trashed on the inside edge. after i fitted my new wheels and tyres i put about 0.7mm toe in on each side in the rear, and about 0.5mm toe in each side on the front.
https://www.sau.com.au/forums/topic/349543-wheel-alignment/#findComment-5620060
My current alignment settings.
Front
Toe: +1.0mm both sides
Camber: -2.15deg
Caster: LHS+4.1deg, RHS+4.5deg
Rear
Toe: +1.5mm both sides
Camber: -2.2deg both sides
The setings my aligner use for the M35 are as follows:
Front
Toe: +.3mm both sides
Camber: -0.58deg
Caster: LHS+6.58deg, RHS+6.58deg
Rear
Toe: -0.4mm both sides
Camber: -0.92deg both sides
https://www.sau.com.au/forums/topic/349543-wheel-alignment/#findComment-5620492
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
