for sale
HKS EVC-S BOOST CONTROLLER
IN GREAT CONDITION ONLY BEEN USED FOR 2 MONTHS
A RELIABLE AND SAFE WAY TO INCREASE BOOST ON YOUR TURBO CAR
THE GOING PRICE FOR THESE ARE CURRENTLY $450 ON EBAY
PRICE $350
msg jayden on 0405 422 600 if you are interested
Accurate HKS electronic boost control at an affordable priceNew Electronic Boost Controller Provides Precise Measurement and Control -- HKS USA, Inc. announces the arrival of its newest boost controller – the EVC-S. By including the most popular features of the EVC, EVC-S offers performance enthusiasts an affordable solution to accurate electronic turbo boost control.
The EVC-S features a solenoid valve specifically designed to accurately control boost pressure up to 250kPa or 36 PSI, 2 boost level settings as well as settings for offset and boost response. Also included are: overboost warning with drop boost feature; peak hold boost readings; after-image display; data lock and an internal diagnostic function. Designed to be compatible with both internal and external wastegates, the EVC-S also complements the current HKS Turbo Timers and AF Knock Amp.
Functions and features of the EVC-S include:
- Affordable model of the HKS EVC series
- Specially designed solenoid valve for boost control function
- Compatible with internal and external wastegates
- Junction connection system allows display unit, solenoid valve and boost sensor
to be directly connected to the control unit enabling an easy installation.
- Display unit is the same design concept as the latest HKS electronic products
and is selectable from kPa to PSI
Easier installation
- Each unit connects independently to the center control unit which processes all signals
- Thin display unit enables free layout
Unified Design
- The same design as A/F Knock Amp. and other HKS electronics
- Unified design for whole HKS electronics product line-up
Price conscious model with specific functions
- 2 control modes (A/B mode)
- Basic parameters Offset, Response
Control range of solenoid duty output = 0 - 100%
- Warning, Drop boost functions
- Peak hold, After image display indication functions
- Applicable for both internal and external wastegate types
- Factory boost function when power is off
- Data lock function
- Diagnosis function for malfunction of boost sensor, solenoid valve or wiring connection
https://www.sau.com.au/forums/topic/349565-hks-evc-s-boost-controller-for-sale/
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
