Hey ppls,
hope someone can shed some light on the issue.
My 34 GTR with just the ignition on,the TPS gauge flickers from 0% to around 2%, but the power FC does not show ant voltage change (0.41v.
Is this normal???
and could it be why when i put my aircon on the LSD-4WD light come on.
do i need to reset the CPU and or do i need to calibrate my TPS,
by the way its a new TPS.
Thanks any advise would be great
mike
https://www.sau.com.au/forums/topic/349571-erratic-tps-34-gtr/
  • Replies 42
0.41 sounds Ok to me
when you mash pedal with ignition on but car not running does TPS % change, the voltage on PFC should also follow
if TPS is toast or out of range the PFC will throw on the engine check light and its name will highlight under ETC, SENSOR SW CHECK with a black background
when does 4WD/A-LSD light come on? every time?, erracticaly? somtimes?
what mods done to the car? has it always been broken or only recently?
Hi, yeah the Fc voltage follows the mfd signal,
the lights come on sometimes, but mainly when i turn the aircon on, after a few minutes or so.
The guy i bought the car off had the same problem so he replaced the TPS but has not fixed the problem.
The gtr has -5 turbos, 600cc injectors, fc boost controller, high flow fuel pump, few other mods but nothing more engine wise.
The TPS i assume has been stuffed for a while. Ive checked almost everything to do with this issue and think its possibly out of range and once the aircon comes on the the engine changes its base idle it sets it off.
i have not done a reset of the fc yet. i have to save the tune first and re-do the idle learn sequence.
Edited by trick
when the engine check light comes on, you need to check ETC, SENSOR SW CHECK and see which sensor highlights
my advice is leave the hand controller on this SENSOR SW CHECK screen all the time and when the engine light comes on look over and see whats highlighted
if the TPS is toast then it will highlight it
a busted TPS or one that goes out of range will kill A-LSD/4WD as the A-LSD/4WD computer in the boot needs constant stable TPS signal to detect how hard you flog the car
if TPS goes out of range the A-LSD/4WD computer will panic and go into failsafe mode, ie light comes on and it stays in RWD/Non vspec mode
no worries ill do just that.
thanks heaps for your help
hopefully i can narrow it down
cheers
mike
i had the same problem about 2 years ago tried everything untill i finally gave up put the stock ecu back in and went to nissan to conect there scan tool and it said the tps was droping the voltage down to .41 at ilde, the minimum it should ever be was .45 at idle so i adjusted it buy loseing the 2 bolts that hold the tps and with a volt meter conected i turned the tps untill it read .45 and then tighen the bolts and recheck it jus to make sure as it was tightened it didnt change and never had a prob since.
interesting, ive been having the random rwd mode problem too.. ill also check my minimum tps voltage
thanks for the info
edit: i just checked it out now, it reads 0.28v on idle and 3.98v on full throttle (engine not running)
Edited by snozzle
also i forgot to mention make sure u test it by pushing the acclerator down and lift your foot of it fast so it springs back and then check it while u ease it off slowly while reading the volts before u drive it to make sure its right as u cant really check it while u driving
Ive got a power fc so its really easy to do it, no need for a multi meter etc. I re-adjusted the tps so that it now reads 0.47v with throttle off (it actually flickers back and forth from 0.46 to 0.47..) and 4.22v at full throttle.
I started the car up 5 times since then and the 4wd has worked every time! Thanks a million for the info, George, and also thanks to the topic starter. :P
yeah have a fc too, adjusted to .45 but only goes to 4.00 full throttle?? should it be more at full throttle??
Thanks to all with the info, saved me time and monies
cheers
mike
  • 1 month later...
UPDATE:
played around with the tps, fluid level and still having the lights come on. thought i had it sussed but it still came on after a few days
my question is has anyone done the wire mod where you cut the pin #56 and join it to the pin #38 on a gtr?
i read the forums and seems everyone was having issues with a gtst with alsd.
is there a way to test if the alsd is getting the tps signal
thanks
mike
do not do that mod, that is for ECR33 only with active-lsd and a powerfc
this is because the powerfc in the ECR33 assumes the car doesn't have a-lsd as only a few models had it
the BNR/BCNR range of powerfc all assume this as far as i know and relay TPS correctly as its needed for the 4WD computer anyway
if it has no TPS signal A-LSD never passes diag when you start the car and it fails every time
so if yours is working and only randomly failing it could be a wheel sensor that is being whacko. does your ABS work OK? any ABS warnings as they use the same sensors
hey paul,
been playing around again with the tps setting it from 0.47v to 0.55 v just to see whats happening.
since playing around the lights come up about 30 seconds once ive started the car.
the fault codes are 72 (tps), but it also flashes 12? what is 12 code?
mike
no idea what code 12 is
if TPS isnt working your car would run like ass, peg its idle at 1500rpm instantly and A-LSD would always be on, among the engine check light too
so the TPS is OK
start your CAR when watching ETC, SENSOR SW CHECK and wait TPS when its working OK, and then watch TPS (and others) when A-LSD fails
does anything change or any sensors go black background
do any other errors come on other than A-LSD ?
but perhaps the TPS to the computer in the boot is being homo
only way would be to work out which wire is TPS relayed signal at the boot computer and check it there
very tedious and annoying
its very weird, sometimes it comes on straight away sometiimes it doesnt at all.
nothing seems to change on the power fc sensor check page, no extra dots.
once the lights come on it locks out some numbers on that page but nothing else.
i may need to test the attesa at the back and check the signal.
if its the abs wouldnt that come up as a fault code?
been testing the voltage at the fc. with just the ignition on the volts to the fc are 0.568, it matches the hand controller voltage. Also the output to the attessa reads the same.
Once ive started the car the voltage at the fc slowly drops to -0.36mv, as if its lost the signal but the hand controller still states it has 0.5v. now im confused. is this a correct reading for tps output or is this why my
fault light is coming on?, but the hand controller says its all good. ahhhhhhhhhhhhhh
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
