66yostagea Posted January 8, 2011 Share Posted January 8, 2011 You probably know I went through the exercise of fitting a Greddy copy FFP. It took a while to do and sort out the AFM problem. It goes so well now I havc backed off the boost to slow myself down. LOL. I have the 25G N/A that I want to front face by modding the top half of the OEM plenum. I have heard it can/has been done. Anyone know of this?? and can point me in the right direction. Link to comment https://www.sau.com.au/forums/topic/349608-oem-plenum/ Share on other sites More sharing options...
KiwiRS4T Posted January 8, 2011 Share Posted January 8, 2011 My Greddy copy was NZ$350. ( http://www.trademe.c...n-345171267.htm Home made versions are $200 -$300 - why would you bother? Here's a how to make the simplest version: http://www.skylineowners.com/forum/showthread.php?t=70143&highlight=diy+plenum Link to comment https://www.sau.com.au/forums/topic/349608-oem-plenum/#findComment-5616061 Share on other sites More sharing options...
66yostagea Posted January 8, 2011 Author Share Posted January 8, 2011 My Greddy copy was NZ$350. ( http://www.trademe.c...n-345171267.htm Home made versions are $200 -$300 - why would you bother? Here's a how to make the simplest version: http://www.skylineowners.com/forum/showthread.php?t=70143&highlight=diy+plenum That is great info. The reason for considering this way is it is so much easier.Like the thread says. I have the top half. I can rework that at my leisure then just bolt it on. TOO EASY. Link to comment https://www.sau.com.au/forums/topic/349608-oem-plenum/#findComment-5616113 Share on other sites More sharing options...
pipster11 Posted January 8, 2011 Share Posted January 8, 2011 you will probably loose power in the 25g tho you need nice long inlet runners for torque and going to a ffp will shorten them quite a lot adapting the stock inlet would probably be the go if you want to get rid of the j pipe Link to comment https://www.sau.com.au/forums/topic/349608-oem-plenum/#findComment-5616521 Share on other sites More sharing options...
Tangles Posted January 8, 2011 Share Posted January 8, 2011 there is one for sale (stock, modified to front facing) in the SA section, I think the seller wanted $350 by memory? the trade-me copy looks nice, wouldnt mind buying that myself. Link to comment https://www.sau.com.au/forums/topic/349608-oem-plenum/#findComment-5616530 Share on other sites More sharing options...
