Mods:
td05-20g
z32
Nistune
Engine:
series 2 rb25det
got my car back from the tuner today , was running sweet as pie , took it for a drive and after about an hour it started to misfire at just over 3,000rpm , first thoughts was a blown cooler pipe as it was when i floored it but that wasnt the problem.
next thing was must be fouled plugs , replaced them with bcpr6es 's and it made it run a BIT better but the problem still existed.
after that i ran the diagnostics on the ECU and it came back with code 43 which is throttle position circuit.
took the throttle body off and cleaned it and also cleaned the TPS to be sure. that did a bit of f**k all ...
next i unplugged it and that didnt change a thing either.
so now , im wondering what it could be
anyone got suggestions?
  • Like 1
https://www.sau.com.au/forums/topic/349626-weird-misfire-problem/
so when you say you "replaced" the coils, did you use new coils or 2nd hand ones?
2nd hand coils = complete waste of time. even the "newest" 2nd hand coils are all old and somewhat tired now. dont piss around. buy a new set. any brand, they all seem to deliver excellent results.
well considering i let someone touch my car and wire something up , i dont have the coin to blow on new coilpacks seeing as i just bought a new z32 and 040 and had to pay for them to be installed cause the car was sitting in a workshop.
the problem isnt coilpacks. its something more serious caused from the person wiring the power on the z32 into the signal wire and vice versa.
  • Like 1
my bet is still on coil packs breaking down under load. when it is boosting. my '32 was doing the exact same thing when i wound the boost up to 14psi it lasted a few days then started to missfire when it was boosting. drove fine at all other times. i ordered some yellowjackets from performance wise through this forum and now they are fitted my car runs sweet. no missfire no loss of power under boost no overfuelling backfires out the exhaust. all good.
i would suggest winding your boost back down if that fixes it it is definatley coil packs. if you gap your plugs 2 low you will still get missfires due to the spark simply not being strong enough to ignite the fuel. i run mine at .9 with yellowjackets and no issues. the missfire started at .8 with new iridiums and standard packs.
the best way of testing your coil packs (without actually buying another set) is to keep closing up the gap of your spark plugs. if you've gone .7, try a .6 gap and see what happens. if it still doesnt fix it on .6 then it may be something else.
Hey just started getting the same problem with my 33 s2 aswell. Took it in for dyno and tune and turned the boost up now it has a really big miss under boost but doesn't have to be alot of boost and it misses. Big miss though. Do you guys think could be the same problem running .8 gap pulled it down to that when i was getting a missfire last year, now the boost back up same thing happening but worse. Did you fix your miss with coil packs mate. Will try the above mentioned fixes and let u know how i go. I also heard that tapping up the coil packs or painting them with clear nail polish to stop any spark leak. Might give that a go too. Let u know how i go cause nothing worse than punching it and getting a huge miss.
Why is everyone ignoring this key piece of info and jumping to conclusions about coilpacks?!
Looks like a short or disconnect of the TPS or it's wiring/harness.
its nothing to do with the TPS.
the wankers who did my fuel pump used carby hose and a hoseclamp that was too big causing the hose to perish and come off of the pump...
they can expect a phone call first thing tuesday from me.
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it    Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher      I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
    • I have a r34 sedan 1999 manual converted need some help with my speedometer it only reads upto 98km and then stops currently still running the auto cluster any easy fixes no speedo drive is connected yet, if someone has a video for wiring up the manual speedo sensor with the auto cluster please send through
