Mods:
td05-20g
z32
Nistune
Engine:
series 2 rb25det
got my car back from the tuner today , was running sweet as pie , took it for a drive and after about an hour it started to misfire at just over 3,000rpm , first thoughts was a blown cooler pipe as it was when i floored it but that wasnt the problem.
next thing was must be fouled plugs , replaced them with bcpr6es 's and it made it run a BIT better but the problem still existed.
after that i ran the diagnostics on the ECU and it came back with code 43 which is throttle position circuit.
took the throttle body off and cleaned it and also cleaned the TPS to be sure. that did a bit of f**k all ...
next i unplugged it and that didnt change a thing either.
so now , im wondering what it could be
anyone got suggestions?
  • Like 1
https://www.sau.com.au/forums/topic/349626-weird-misfire-problem/
so when you say you "replaced" the coils, did you use new coils or 2nd hand ones?
2nd hand coils = complete waste of time. even the "newest" 2nd hand coils are all old and somewhat tired now. dont piss around. buy a new set. any brand, they all seem to deliver excellent results.
well considering i let someone touch my car and wire something up , i dont have the coin to blow on new coilpacks seeing as i just bought a new z32 and 040 and had to pay for them to be installed cause the car was sitting in a workshop.
the problem isnt coilpacks. its something more serious caused from the person wiring the power on the z32 into the signal wire and vice versa.
  • Like 1
my bet is still on coil packs breaking down under load. when it is boosting. my '32 was doing the exact same thing when i wound the boost up to 14psi it lasted a few days then started to missfire when it was boosting. drove fine at all other times. i ordered some yellowjackets from performance wise through this forum and now they are fitted my car runs sweet. no missfire no loss of power under boost no overfuelling backfires out the exhaust. all good.
i would suggest winding your boost back down if that fixes it it is definatley coil packs. if you gap your plugs 2 low you will still get missfires due to the spark simply not being strong enough to ignite the fuel. i run mine at .9 with yellowjackets and no issues. the missfire started at .8 with new iridiums and standard packs.
the best way of testing your coil packs (without actually buying another set) is to keep closing up the gap of your spark plugs. if you've gone .7, try a .6 gap and see what happens. if it still doesnt fix it on .6 then it may be something else.
Hey just started getting the same problem with my 33 s2 aswell. Took it in for dyno and tune and turned the boost up now it has a really big miss under boost but doesn't have to be alot of boost and it misses. Big miss though. Do you guys think could be the same problem running .8 gap pulled it down to that when i was getting a missfire last year, now the boost back up same thing happening but worse. Did you fix your miss with coil packs mate. Will try the above mentioned fixes and let u know how i go. I also heard that tapping up the coil packs or painting them with clear nail polish to stop any spark leak. Might give that a go too. Let u know how i go cause nothing worse than punching it and getting a huge miss.
Why is everyone ignoring this key piece of info and jumping to conclusions about coilpacks?!
Looks like a short or disconnect of the TPS or it's wiring/harness.
its nothing to do with the TPS.
the wankers who did my fuel pump used carby hose and a hoseclamp that was too big causing the hose to perish and come off of the pump...
they can expect a phone call first thing tuesday from me.
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
