Of course I wouldnt do it cold, I NEVER take it above 2500rpm until the temp gauge is in the middle I'm sure the people who get stuck behind me in morning traffic are spun out that and R32 is being driven like a grandma but I want the engine to last.
Just out of interest If the limiter was removed would going just a tad over 8000rpm do any damage to the engine?
you want the engine to last but you are talking about doing launches in first gear from the limiter? doesn't make sense to me.
the rev limiter is probably set at about 7500rpm, but it's probably that your tacho is inaccurate (remember that they are old cars now). a mates 32 tacho read well over 500rpm out at redline compared to the PFC reading.
yeah i guess that is a bit of a contradition, but then again reving the tits of a cold car every morning would do alot more damage than 1st gear launch every week or 2 right?
if the limiter kicks in at 8000 but the redline is 7500 due to the incorrect tacho
is it likely that idling speed states 950 its actually closer to 500? isn't that a bit low?
should be ~700
the tacho will not read exatly 500 out across the whole range, it will vary
correct. generally it will be out be a percentage, not a set amount (just like the speedo will be). if the tacho is out by 10% then at idle it will be out by less than 100rpm, but at redline it would be out by nearly 1000rpm.
if i decided to be anal and replace and buy an APEXI RSM rev speed metre will it read correctly?
it will be accurate, as long as it's setup correctly, LOL.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
