Hey,I'm just wondering if anyone can help me or list all the bulbs that the 1998 Nissan Skyline R34 GT-T uses ?
Because it doesn't tells me in the owner's manual ?
Thanks
Edited by Jeremy1607
https://www.sau.com.au/forums/topic/349684-1998-nissan-skyline-r34/
Okay,thanks guys.I see that T10 wedge is the same as W5W ?
And if I want to install both the low and high beam HID kit,does that means I really have to uses 4 ballasts because there 4 different bulbs ?
Does it use W5W aswell ?
Thanks
Thanks
Yes you would have to use 4 ballasts, one for each globe, not sure about the W5W globes, T10's are easy enough to come by
You would need 4 ballasts for four bulbs.
It's generally not recommended to have HID on your highbeam (I believe it's because they take time to warm up, so flashing them doesn't work very well, and you typically turn highbeam on/off more, which is bad for the life of the bulb/ballast).
What's wrong with just a standard decent bulb in the highbeams? If they're HB3 connector highbeams as they are on mine, you could consider fitting HIR bulbs maybe? That would be a decent compromise in my opinion.
  • 4 weeks later...
One more things,a couple weeks ago I had Autosparks to install my HID kit.
When it's done,I noticed that all the wiring is completely different,now with rubber thingy,different cable and etc.
But I noticed the right headlight wire that connects to the end of the bulbs is loose.Sometimes the right headlight would turn on,but then if I go through speed bumps or bumpy roads,
the next time I turn it on,it wouldn't light sup,do you have any idea to fix it ?
Or should I just go back to the workshop who changed all my wiring and things ?
Because it wasn't like this before they changed it.
  • 2 months later...
For Skyline GTT if you want to do interior, number plates etc.
Front(X2) and rear inner sidelights(X4) - T10 501 capless or W5W(Same thing)
Number plate illumination(X1) - T10 501 capless or W5W
Side indicators - T10 501 capless or W5W
Interior map lights(X2) - 9mm bayonet(BA9S)
Middle interior light(X1) - 31mm festoon
Boot light - T10 501 capless or W5W
Rear outer sidelights and brake lights - T20 capless dual filament.
Rear indicators - T20 capless
Reversing lights - 912, T15 capless with 9mm base. Or you can use any bulb with T10 W5W base(IE 6/9 LED bulbs)
Courtesy of Skylineowners.com :thumbsup:
  • 5 months later...
:thanks:
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
