SO you know how to fix or modify your car but dont have the facilities to do the work????
M'Mates Place
DIY Automotive Repaires Workshop
2 poster hoists - 4 poster hoists - belly lifter - spray painting booth - preperation booth
Engine building room - car storage - air tools - hand tools Everything you need to carry out the work just drive in do the job and go avaliable buy booking on a very cheap day rate!!!
Michelle Osborn
Managing Director
0467 546 831
Grande Openning Feb 13th at 10am plenty of tuff Drag, Drift, Burnout and street cars on display with a free suasage sizzle and bouncy castle for the kids!
Workshop open for veiwing and people avaliable to answer all questions about the facilities!!!!
BE THERE!!!!!!!!!!!!!!
https://www.sau.com.au/forums/topic/349773-mmates-place/
    • Yep it is overflowing. All was working fine but been off for a year so guess something may have seized. Steering is heavy yes   i will raise the front of the car and will turn side to side to test id bubble goes away
    • Does the steering feel heavy when you turn the wheels? Any puddles of fluid on the floor or that you can see leaking from anywhere? You could try bleeding the system, if it’s making a whining sound when turning the wheels then that’s a sure indication there’s air in there somewhere. Start the car and remove the reservoir cap, then turn the wheels from left to right a few cycles and then check if you see any air bubbles rising to the top of the reservoir. Top up if necessary and repeat. Otherwise, I can only suggest that your pump vanes have seized or that there is a perished seal somewhere??
    • No idea. It's too weird.
    • The jack holds itself in place. You slip it down into the receptacle and give the input a twist to open it up a little and jam itself in there.
