Can Someone Lend Me Stock Rear Suspension For Rwc?
Hey lads,
Need to borrow someones stock rear suspension for a RWC. Need to have the stock boots intact, as thats why the tester knocked me back (shock boots on my struts are busted out).
Any other rear suspension will also be fine as long as they have boots!!
I'm happy to come and pick them up. I'll throw $50 your way too.
Need before the weeks end!! Help a brother out!!
Cheers.
Edited by rbjunkie
Why don't you go grab yourself some spring compressors and some new boots and fix em properly? I imagine it's a pretty simple job. getting the struts out can't bo too hard and then its simply a matter of compressing the springs and getting the strut tops off (can be a little tricky - take em to a mechanic if you can't get the nut off). If you have the ability to change the shocks over then I predict you have the ability to change the boots.
It probably wouldn't cost you $50, you don't have to rely on anyone else, and you won't have to worry about it ever again!
  On 13/01/2011 at 8:08 PM, rbjunkie said:
Boots are over a month wait from japan..
Bugger.
Get an idea of size and I reckon you'll easily be able to source some boots from another make which will fit. After all, they don't really vary a great deal from make too make. Just a little longer or shorter and a little bigger or smaller. Close would be good enough I reckon.
Either that or take em off. I don't think boots are an absolute requirement, are they? I've owned plenty or cars which did not have boot around the strut.
