R32 Rb26 Dett
hey guys
Up for sale is a complete running gear,to suit rear wheel drive application.
Engine:
Engine has been freshened up with new buttom end bearings
garret 2860-7 turbos
power fc pro
greddy timing gears
greddy fuel rail
sard 700cc injectors
tomei fuel reg
tomei type 2 pon cams
spilt fire coil packs
walbro fuel pump
greddy pro spec b boost controller
vehicle made 343rwkw at 17 psi.
gearbox has been mod to suit rear wheel drive with transfer case internals removed
gearbox has been rebuild with all new support bearings.
gtr rear diff with nismo 2 way diff
im asking $11,000 firm for complete package,and im located in victoria.
you can contact me on 0406 942 756. tanks guys for ur time to look
picture can be give on request.
 Share
    • Thanks gents, I think I'll get a PSR and see how it goes. I saw an interesting video in YT where a guy stripped one and the bearings were similar to the GTX series instead of the newer G series, but for 40% of the Garrett price I suppose there has to be some sort of trade off!
    • My opinion is they aren't worth double at all.  Have used a good number of Pulsars with builds I've been involved with and tbh at least speaking for myself, Garrett aren't losing money they'd be getting if Pulsar didn't exist as for genuine Garrett money I'd probably be buying something other than Garrett.    We've used Pulsar 6262G (G35 900 equivalent) on an RB26 with a twin scroll hotside and it picked up 40wkw at the same boost over the old twin -5s and the improvement in transient response over the twins changed the car - this is before you factor in the amount of further headroom of the G35.  Have also used one on a 2JZ drag car which has run 9.6 @ 141mph not even trying, from what we've seen so far it'll potentially go 8s when we turn it up  Crazy results for what is basically a NZ$1500ish turbo.
    • Mate i've used PSR turbos for years now and have never had an issue with them, the wheels measure the same as the real thing and i've seen them make the exact same power on the dyno pretty much back to back. Its upto you whether you'd want to spend the extra cash.
    • Sorry to change topics here, but does anyone know where to get the O-ring for the radiator drain plug?  I want to change the coolant this weekend but the manual says we should not reuse the radiator drain plug O-ring again? I did some Google search and is now getting bombarded with ads for a radiator drain plug kit 🤣 is that the O-ring? (posted pic of said ad) PS: @PranK Looks like I just needed a higher rank to post pics! It works now 🙌🏾
    • more new rubbers and to add to the mix  also new bolts for the center garnish and pretty much all done, the alarm is being replaced and I’ll deal with that ugliness when that happens
