just wanting to put a 3 speed auto with trans break or something along those lines in my r33 gts have any one done the turbo 400 into the r33 or vl boxes? just wanting to know what direction would be the easyest while keeping cost down as a modded r33 auto to handel 500rwhp is exspensive.
https://www.sau.com.au/forums/topic/349853-vl-auto-or-t400-gear-box-for-r33/
  • 3 weeks later...
I bought a C4 with 3800 stall from Fred @ Protrans. I just had to make a gearbox mount and have the tailshaft modded.
It got a transbrake. My 33 made just under 500rwkw.
What speedo drive do I need to work with the R33 dash. I need a speedo that works. lol
  • 2 years later...
Did you have an auto before or manual? How low is your car? What's your goal? Drag or daily? A T400 from a chevy has a deep pan. Might drag it over speed humps. Castlemaine Rod Shop in Victoria sells adapters for 350/400/700. It's been done. I built a RB26 with a 700 attached for a guy here in the US. Put it in a sand rail for him.
Not a 26. Meant a 25
So pricing back for a C4 setup from Al's autos will come in around $6500 for box and converter or around $9000 fitted.
EEK! after cooking a built GZM re401a ($4500 later), I'm not sure what to do!
Edited by Caelen
I just had a re401b built by mv autos for under $3500 with converter full manual valve body etc. I like the 4 speed option of the jatco
Do they give an estimate as to what the box will handle and what are the differences if going from type A box to type B (wiring, overdrive, drive shaft lengths?
Sorry to sound like such a noob, Only just getting into the world of skylines coming from 4x4's.
They said they had a customer with 500kw in a 33 drag car for 2 years with no problems. I have the overdrive on a switch and it's a direct replacement for the a box
Thanks mate! will get on the buzzer to them now, sounds good!
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
