just wanting to know what power my 32 gtr can make safetly it currently makes only 314kw on bout 20 psi it needs a full tune again ,including cold start tune. iam moving to perth real soon and was goin to get it tuned over there any places recomended ?
ENGINE: *CP pistons
*Eagle rods
*N1 oil pump
*Tomei sump baffles
*Tomei headgasket
*Tomei oil feed restrictors
*custom oil drian from the rear of the head to the sump
*balanced crank
*acl race bearings throughout
*N1 water pump
*Apexi cams ( not sure what lift)
*Aftermarket vavle springs
*Hks cam gears
*Hks timing belt
*Bigger Fuel pump
*700cc sard injectors
*adjustable fuel reg
*Nisstune ECU
*twin Garrett 2860-5s
*Huge intercooler
*Alloy radiator
*Front sway bar
*middle sway bar ( in photo of interior)
*rear sway bar
*Bilstein coilovers
*torque split controller( not working at the moment will try to get fixed before sale)
*drilled rotors
*gauges, oil pressure, boost
*Alpine headunit
*Alpine 6x9s
*oil filter relocation kit
thanks guys
What air flow meters is it running. Stock ones would be maxxed by now so I'm assuming Z32's or something like that?
Those turbos should be good for about 400kw at the wheels but only a few have made it there reliably.
Also the injectors will be ok there but they are rubbish for idle mixtures as the latency sucks. And depending on the fuel pump as well, it just says bigger, doesn't say how big. The power is off for the boost it is running though. 20psi should be nearing 480-500hp from the ones we have done
when u say a few made it there reliably what ya mean ?
ok afms i will find out should they have brown label ,orange label on them if they are z 32 s?
fuel pump i will find out but it deff is loud as i can hear it at back of car when running winding off its head.
its currently making 314 kw
but has made 458 kw by original owner on 28 psi
anyone else got some views on this ?
cheers
well 8psi of boost doesn't net you over 140rwkw, so 458 sounds wrong.
there are explicitly few cars who've made over 420rwkw with that sized turbo, and we are talking full house workshop cars. Your build is nothing close to those. so another flag post for the '458' result.
realistically you can expect 350awkw at 20-22psi. that is what the MAJORITY of -5s/2530 set-ups make. some make more, some make less but basically that's what you'll get. very unlikely it was making 460kw even with 28psi....
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
