while i rather enjoy watching drift, ill be keeping my pennies for a couple sprint days instead.
have fun, ladies!
I'd go if my paint wasnt so schmick! :teehee:
lol. righto.
maybe if there was more time i would be keen.
dang!
its 2 months...
  • Like 1
  • Nope 1
Hold up, didn't you're Stag get stolen too? Man that's bad luck! You didn't have it long!!! How did you bin it?
yeah 2 cars in 3 months written off,shit times
turned into a slip lane and clipped the yellow concrete markers that segment the slip lane from the main rd and it jump the car (stiff as bilsteins) up on one side,car Landed,slid,was way too far gone and just as I got it straight ran out of road,up the gutter into a tree
was new years day so the cop was super suss,blew zero and an elderly lady witnessed it and confirmed with him what happened and that I wasn't speeding or being an idiot so he just cautioned me instead of dishing out driving without due care fine
oh well,gtr coming soon
have fun, ladies!
lol. righto.
its 2 months...
yes but i need to wait for injectors to come from the states, and tune. pay the deposit and risk that not coming intime.
yeh ill have to pass on this one!
Drifts not for everyone, atleast they were given the opportunity.
Grip is just as harsh on the car though guys, look at home many cars broke down at the grip day, lots and lots, I was actually surprised with how many cars died halfway through the day!
sprints if anything are a lot harder on hardware than drift is.
drift youre tearing the shit out of it for 45 seconds and then stopping for a couple minutes.
in a sprint youre driving 10/10th's for 10, 15, 20 minutes at a time.
drift is only harder on the car when you inevitably hit clems tyres. :laugh:
hence why a lot of people don't want to try it
id drift
but ive proved before i suck epic amounts of cock
and the new car isnt quite attune to it
oh well, i'll stick to sprints
Is that at drift or just in general :P
And damned you for not putting on my shoutouts the other night on Fresh!
Guest
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
