1994 S14 S1
Rego till 27.04.2011
Travelled just over 160,000km. Of which I have only done about 10,000.
Compression tested before purchase, came up at 140psi +/- 2psi
Serviced every 5,000km with Fuchs Titan SyperSyn 5w-40
Gearbox oil has been replaced with Redline Super Lightweight Shockproof gearbox oil
At 155,000km taken to Dr Drift where he tuned and installed:
Nistune,
Gktech rocker arm stoppers,
brand new Z32 AFM,
Turbotech boost controller, and
3A Racing air filter.
With 100ron petrol (United 10% ethanol mix) she reeled off 161.4rwkw, maxing out the injectors because of the ethanol blended petrol. With bigger injectors will make 180-200rwkw easy.
Other modifications include;
HKS Hyper D coilovers,
APS Front mount (no holes),
Walbro GSS-341 in tank fuel pump, installed about 1000km before tune,
Relay directly wired to fuel pump,
Relay directly wired to coil packs,
HEL Braided brake lines F+R,
Slotted RDA front and rear rotors, not even 1000km old,
EBC Green Stuff front and rear pads, not even 1000km old,
Rear Whiteline 22mm adjustable swaybar with new front swaybar links,
Autometer 2 1/6" Boost gauge on steering column,
Brand new wheel studs on all 4 corners,
Unknown brand 3" turbo back into a Magnaflow rear muffler.
Parts I'm willing to sell at extra:
Powered by Max subframe risers,
Superpro front swaybar D bushes,
Brand new front tie rod ends,
Brand new front swaybar links (Mitsubishi GTO, will explain to the purchaser how to put on),
Superpro polyurethane steering rack bushes,
and finally a set of GKTech Tie rod end lock spacers.
Also have a brand new externally gated turbo from APS, it is a Mitsubishi/Trust turbo, slightly bigger than a T28, but externally gated.
No rust, no damage.
Comes rolling on freshly painted 32 gtst rims, and a spare set of S14/R33 gtst rims.
Asking price, with all above parts, $11,000.
Just the car, $9,500.
Will consider swaps for a cheap slider, S13 or the such (possibly track only), plus cash my way, or a daily + cash, must be manual.
PM me if interested.
https://www.sau.com.au/forums/topic/350002-zenki-s14/
  • 1 month later...
    • No-one in Aus/NZ would pay that much, because they remember when a turbo Skyline/Silvia was a cheap but awesome alternative to the mediocre shit sold here locally at the time. I'm sure over in USA there are enough trust fund kids who will have their R34 GTR, whatever the cost
    • I am stuck with enthusiast and very unhappy, even though Lumley, Shannons and Famous are all options, they all require a lock up garage, and my situation (basically a walled off compound from the street) is insufficient because the car is under a carport. I'm confident to resolve the situation I need to build a roller door with fascia in-front of my roller gate which is a solid opaque metal rolling gate. In any other universe moving the roller door 2 meters in-front of the garage door would still constitute the same amount of security but oh no. My insurance rates suck to the point of when I joined a market research for Enthusiast they were all surprised that I paid about 2-3x what other people were paying with Enthusiast when I asked them why their rates were so high. If I lie about having a garage, I save like $10 a month with enthusiast. (It's about $2600 p.a for 5000km of driving for a very unsustainable agreed value). Lumley has terrible reviews but @Duncan made me consider calling them when renew time came up - but their horrible reviews plus Christmas time made me... forget.
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
