1994 S14 S1
Rego till 27.04.2011
Travelled just over 160,000km. Of which I have only done about 10,000.
Compression tested before purchase, came up at 140psi +/- 2psi
Serviced every 5,000km with Fuchs Titan SyperSyn 5w-40
Gearbox oil has been replaced with Redline Super Lightweight Shockproof gearbox oil
At 155,000km taken to Dr Drift where he tuned and installed:
Nistune,
Gktech rocker arm stoppers,
brand new Z32 AFM,
Turbotech boost controller, and
3A Racing air filter.
With 100ron petrol (United 10% ethanol mix) she reeled off 161.4rwkw, maxing out the injectors because of the ethanol blended petrol. With bigger injectors will make 180-200rwkw easy.
Other modifications include;
HKS Hyper D coilovers,
APS Front mount (no holes),
Walbro GSS-341 in tank fuel pump, installed about 1000km before tune,
Relay directly wired to fuel pump,
Relay directly wired to coil packs,
HEL Braided brake lines F+R,
Slotted RDA front and rear rotors, not even 1000km old,
EBC Green Stuff front and rear pads, not even 1000km old,
Rear Whiteline 22mm adjustable swaybar with new front swaybar links,
Autometer 2 1/6" Boost gauge on steering column,
Brand new wheel studs on all 4 corners,
Unknown brand 3" turbo back into a Magnaflow rear muffler.
Parts I'm willing to sell at extra:
Powered by Max subframe risers,
Superpro front swaybar D bushes,
Brand new front tie rod ends,
Brand new front swaybar links (Mitsubishi GTO, will explain to the purchaser how to put on),
Superpro polyurethane steering rack bushes,
and finally a set of GKTech Tie rod end lock spacers.
Also have a brand new externally gated turbo from APS, it is a Mitsubishi/Trust turbo, slightly bigger than a T28, but externally gated.
No rust, no damage.
Comes rolling on freshly painted 32 gtst rims, and a spare set of S14/R33 gtst rims.
Asking price, with all above parts, $11,000.
Just the car, $9,500.
Will consider swaps for a cheap slider, S13 or the such (possibly track only), plus cash my way, or a daily + cash, must be manual.
PM me if interested.
https://www.sau.com.au/forums/topic/350002-zenki-s14/
  • 1 month later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
