And plenty of stock motors have blown up too. We need know the how many and the how of the failures to be able draw useful conclusions.
well my oil pump failed at 397awhp, no idea why. seans car is stock but with a billet pump and crank collar. that gmastr 32 which is tuned at jem makes 400kw now, totally stock with the narrow drive .....
Mostly from what I've gathered reading the engine failure thread over the years, is usually one of the following:
- turbo failure, ceramic exhaust wheel is jettisoned into the catalytic converter and ceramic dust makes it way into the cylinder bores via the exhaust valves. (it may have been mentioned by a builder or tuner that they've seen this happen 25% of the time)
- spun bearing, poor choice of oil or poor maintenance or not overfilling (sump emptied, resulting in oil starvation or due to no upgraded oil sump baffling) or just plain unlucky (or all 4)
- oil pump failure. limiter bashing (hard ignition cut). early short oil drive crank more susceptible to failure than the long oil drive due to smaller oil pump <-> crank surface face. Newish N1 oil pumps are considered junk (it's speculated that manufactoring process different from early N1 pumps)
- poorly assembled "built" engines that go pop easily. pays to have a engine builder who has built hundreds of RBs (red r racing etc), not a shop that is learning as they go on your engine. Personally I would take an unopened factory engine over an RB put together by a random shop.. common thing with "built" engines is bearing clearances completely wrong
- 100,000km service gone wrong. wrong belt tension (belt skips teeth and pistons meet valves), or balancer not torqued to spec and working itself loose (which the oil pump relys on) or even not bothering to do the full service and leaving the factory fitted tensioners etc fitted which then seize.
- Poor tune, especially Jap ECUs, often brought off ebay and put into cars without checking it on the dyno, especially Mine's... completely unsuitable for australian fuel/conditions
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
