hey,
Im looking to replace my bumper, as it has some damage to the driver side on it and was thinking i might just sell the gtr pods on it and replace the whole thing, but the only problem is i am having problem find anything remontly nice :P
i would like something to match my car nismo front bar and 400r side does anyone have any idea of a good 1?
Ok now onto the crazy ideas :D
1. r34 headlights onto a r33 is it possable and wat are peoples comments of how they would think they would look (tring to do a photochop but dont have any pics of r34 headlights) the reason this has come around is i need 2 replace of my headlights (damage) so i was thinkng i might do something different
2. My dad had this crazy idea and i was wondering if it would work, he said i wonder if u can hook the aircon up so it blows into the turbo, so some how connect the aircon to the intake pipe (where air filter is or make 2 pipes so still have air filter) and when turning on the aircon have coldair pump into it.
This idea has 1 major problem i think is that when the aircon is on the car seems to run alittle less quick and maybe the gain will just be as if it was running withou the aircon
any input would be helpful of all subjects :)
thanks Mike :headspin:
  • Replies 41
thanks for the photo prae :)
hmmm looking at the photo i am still not sure if it will work so good or even look so good confused :P
dan, i have no idea how the aircon works but i wonder if u could make a little aircon unit that has its own power supply and doesnt run off the engine and use that, my dad knows about those things so i will get him onto it when he gets back from work 2day.
Crazy ideas look wat happens when i dont go 2 school ahahaha :D
i had an idea back in the day when i was still wanting a v8 (hehehe how things have change) and i was thinking if adding a some vucum onto the intake pipes so that air is suck in faster therefore more air,
dont know if that would work again just another crazy idea
yeah dan_the_man is right, your turbo sucks a lot of air through the airfilters, an air conditioning unit wont even have close to enoguh power to make a differnce, i had the same idea when i was supercharging my bmw, also im not sure about this but the air that is coming out of the A/C unit isnt oxygen enriched like air from the atmostphere, which means even though its cold your engine be able to burn it as good as normal air, correct me if im wront.
If you use R34 lights you'll probably need to use R34 bonnett to match them ....then you'll probably need front bar to suit R34. I've just gone that route putting R33series 2 lights on my series 1. Series 1 bonnet and front bar no longer lined up properly
ok r34 lights r the go ahead :(
but only problem is i need a kit maybe someone could help me out, maybe rezz can come in and help me out
just get a bodykit instead of the stock R34 one if its better (eg: do luck, nimso etc)
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
