Hello guys!
Just a bit of question about the small clarion amp in the trunk.
Today, when I was checking out mine I saw that the harness plug for the said amp was unplugged, and has been plugged to some kind of bypass socket. When I did plugged the harness back to the oem amp. My rear speakers stopped working. Is my amp busted or it has been bypassed for another kind of sound set up?
Thanks in advance!
https://www.sau.com.au/forums/topic/350080-gt-r32-oem-amp/
the white plug that you pulled out when you started investigating theis. your assumption is correct. that amplifier generally does not work once you pull the stock radio out.
https://www.sau.com.au/forums/topic/350080-gt-r32-oem-amp/#findComment-5625650
