i was told by a friend that he has someone who makes gilmer drive set for gtr, he told me he saw one that had the set and sounded absalutly crazy while it was driving past.
down low befor it spools up sounds like a supercharger whinding up, and then the turbo kicks in and you can hear the spooling of the turbo, i was wondering if anyone was interested im buying a set, as i wanna take my car down and see if i can get one made for myself,.
and also if anyone has a set on their car, can you tell me if it makes any differnce, or how does it sound on your car and do you or do you not recomend it. :wassup:
https://www.sau.com.au/forums/topic/35010-gilmer-drive-set-for-gtr/
  • Replies 54
squirrel goes weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!
OHHHHHHHH!!!! I SEE!!!!!!!!!!!!!
So it makes my car sound like THIS!!!: http://www.goofyville.com/viewflash.php?na...1car&position=0
Like Judd said, Gilmer drives are machined pulleys that are toothed (think RB cam gears) to run a toothed belt (think cam belt), instead of a V belt. They are usually used in high revving applications or applications that run external oil pumps, superchargers and mechanical injection. A side effect is the high pitch whine, which is very annoying.
the belts are primarily designed for peventing belt slip on supercharged motors. They drain a fair bit of power.
If you have slip on the standard single belt then go twin belt pulleys (lose some more power). If they slip then look at a gilmer (lose even more power again).
If you like the mean sounding grinding noise then make up a little idler pulley to bolt on the motor somewhere that turns a set of straight cut gears (for no reason other than to make noise as you rev the engine). *$#%'n rice boys! :(
apparently they dont drain a lot of power, from the turbo engines, only on the supercharged engines cause they use the crank of the block to produce boost, but as was said for high reving engines they are very efficiant and will help prevent belt brakage due to strain on the standard v belt, and you dont want to snap a belt and bend a valve, $$$$$ to fix.
anyways i will have mine hopfully next week, and for those who think the whining noise is annoying, i hope you think that from expericance cause if you havnt heard one, you dont know what your missing out on, sounds very hektic when on show or pulling up next to cops,, hahahahahh stupido police would probably think something was wrong with your car and leave you the hell alone.
:flamed:
the belt thats on glimmor drives is about 3-4 inches wide, you see the glimmer come up on the supercharged cars with the charger out the bonnet. (big fat belt on a big arsed pulley with big teeth)
hey sumo, they dont have to be 3-4 inches wide, kits come anywhere between 1-5 inches, most applications are about 4 cm which is under 2in, its not the thickness of the belt that matters, its the straight cut teeth on the lightened alliminium pulleys that help the belt not slip at high revs
Mr. Wrecked Head, the belt used to connect the cam gears to the crankshaft is already a tooth gilmer-style one. If a police officer thought something was wrong with your car do you think they would leave you alone or bear closer scrutiny... like a roadside defect inspection?
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
