Hey guys, not sure if this should be in this thread of the whole car forum but im parting ways with my 1989 r32 gts-t with s2 rb25det. The rb25det conversion was done approx 2 years ago, and was a full conversion inc gearbox.
I have owned the car for the past 6 years after importing it myself and having graduated uni im about to move for work so its time to part ways. Car would be perfect for either an enthusiast willing to put some work into it or alternatively as a running wreck. The car is still registered until June and running so you are welcome to come out and see the engine/gearbox in running condition. The primary reason for selling as a wreck rather than registered is that im rather busy at the moment so I do not have the time/energy to get the car a road worthy however im comfortable if the buyer wishes to do this themselves while the car is still registered to save hassle.
Notable specs of the car are:
185,500 k's (64,000 on the series 2 rb25det)
rb25 gearbox and running gear (when the conversion was done, all mounts was custom fabricated so this would suit either an r32 with the mounts provided or an r33 with your own mounts)
Recently replaced high flow radiator (purchased from one of the SAU group buys)
Recently replaced bosch fuel pump
Apexi turbo timer
HKS boost gauge
Momo steering wheel
17" rims
Things that require work is the body. There is a dint about the size of a 50c peice in the rear near the tail lights, along with a dint in the drivers side door where a trolley has hit the car. The car could generally use a paint job also and a few of the seals are starting to wear/peal due to age. There is also a dint in the passenger side front quarter however replacement guards will be provided so that shouldnt be an issue.
There is honestly alot of other extra's (skirts, stainless dump pipe, high flow exhaust eg), i'm currently in a flood effected area of South East Qld (although the car is safe!) and as soon as the flood water resides I will go out and photograph everything.
Asking $7,000 as an unregistered rolling wreck but as I said im happy to help the buyer out if they wish to get a roadworthy to keep the car registered. As I also mentioned im not thrilled on separating items of the car at this stage but if a few different guys are interested in taking different parts (i.e someone wants shell, another engine and gearbox) im happy enough to do that.
Contact Matt on 0409055258
Edited by Tizzle
https://www.sau.com.au/forums/topic/350118-wrecking-r32-gts-t-with-s2-rb25det/
  • 3 weeks later...
  • 3 months later...
Hey guys, FINALLY have some pictures up. I've highlighted the notable damage to the body being the front left guard and the rear right corner. I have a set of fibreglass vented front guards that I paid $450 for about a year ago that I am happy to include in the sale to be used to replace the front guards.
Any other questions either pm or for a faster reply text on 0409 055 258
  • 3 weeks later...
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
