looking at importing in the near future, not sure which model to go after though, my only necessity is that it be a series 2 and auto.
i'm in perth and have been told that iron chef imports are a good choice, i would prefer to go through a WA importer, but dont know of any here,
is it much of a hassle going through an interstate importer? and i'm looking to spend up to 14k
https://www.sau.com.au/forums/topic/350130-s2-auto/
Why import one? There are plenty of these in Australia already and you'll have more guarantees if you buy one off someone on here. Most people go for an import when they're after something more unique or if they want to save money. On a s2 I doubt you'd save much since there are so many around and the local prices are pretty low already. The only part you save on when importing is the actual price of the car in japan. To give you an example, a car that costs $17000 to import may only cost $5000 in japan, so even if you get a cheap one in japan you may only save yourself $1000 or so maximum, not really worth it if you ask me - compared to seeing, inspecting, and test-driving one over here. It made sense to import them when there wasn't many here and you may still get a good deal on a newish M35 if you import one...but 14k will easily get you a good series 2 auto.
to answer the other point, iron chef imports are good, very honest/reliable from what I've heard.
But yeah, have a good look around on carsales and on the for sale thread in this forum - I think you'll find what you need already in Australia.
https://www.sau.com.au/forums/topic/350130-s2-auto/#findComment-5623095
+1 to buying locally
My s2 C34 cost me 14k and it came with coilovers, fmic, full exhaust, hiflowed turbo and a Haltech.. bargain!
P.S. the WA subsection of the forums has info on importers and workshops in the Consolidated Workshops thread.
Edited by bubba
https://www.sau.com.au/forums/topic/350130-s2-auto/#findComment-5623153
Recommend iron chef imports. I wouldn't worry about then not being local to you. They are local to me but when I imported my s2 c34 it wouldn't have made a difference if local or not as it is all done over the phone and emails.
Local prices are low but you might still find something a bit special importing too.
https://www.sau.com.au/forums/topic/350130-s2-auto/#findComment-5623946
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
