I just found out today because my car is an automatic,it'd cost around $3,500.00 to remap or install the new piggyback ECU or something ? Not really sure.
someones taking you for a ride...
just go with a nistune board. install.. remap and away you go
  • Replies 53
Posted Images
What will the NISTUNE do to my car exactly ? Sorry I'm not really familiar with this kind of things as I never had a turbocharged car before lol.
Edited by Jeremy1607
In this case I would be either doing a lot of reading on here, or just find someones setup that you like and copy their setup and take it to the same tuner (obviously must be local to you and run an automatic gearbox).
It is like getting a full aftermarket ECU as it lets you retune ignition and fuel maps in real time as well as tweak some other things.
Well I think the 230kw figure is a load of crap and I doubt with a stock ecu you are making over 180, so normally you'd see ~200 with the neo turbo. It is also a required upgrade before you can do anything else, can't go bigger turbo or change injectors without it.
Should see better economy and smoother acceleration definitely thoug, really need to see what it is like on the dyno now to see how much of an improvement there can b, some look worse than others and have a huge dip in the midrange due to it richening up.
Edited by Rolls
yep, i had my ecu remapped with a nisstune and it cost me $650.... and that was an auto ecu in a manual conversion
Yeah,I asked Imports 101 and they said they'd charge $1,500.00 for the Nistune,fitted,tuned and tested ? How come it's expensive compared to other workshop ?
Also regarding lowering the car with king springs,here in Perth Ian Diffen or Tech 9 Tyres can do them for $500 fitted but Imports 101 said they can do it for $750 fitted ?
Is it good service or a rip off ? Where did you do yours ?
Thanks.
They also said that I will need boost valve bleed or something for $130 fitted or a good controller for $750 fitted ? Altogether you'd be looking for $2,000.00 ?
Usually for the Nistune drive in drive out with a tune shouldn't be more than $750, i think $1500 is a bit steep for it, Instead u can get a power FC + Tune for around $1700.. I suggest you check around other places for the Nistune because its great bang for buck!!
Thanks.
Ring around, that is steep even if they are great tuners. A boost controller is not needed for stock turbo, an exhaust will cause it to run 10-12psi anyway with an rb20 actuator.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
