Guest darrinspencer Posted February 25, 2004 Share Posted February 25, 2004 Would the cam shafts out a 34 NUR GTR engine be a worthwhile upgrade over the standard cams in 32 or 33 gtr engines? I do not know the spec of these cams, does anyone know? Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/ Share on other sites More sharing options...
JezR31 Posted February 25, 2004 Share Posted February 25, 2004 i would think so. Since the NuR models got the N1 engine Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/#findComment-700078 Share on other sites More sharing options...
OKBANANA Posted February 25, 2004 Share Posted February 25, 2004 Would the cam shafts out a 34 NUR GTR engine be a worthwhile upgrade over the standard cams in 32 or 33 gtr engines?I do not know the spec of these cams, does anyone know? id go the Nur cam shafts if i were you Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/#findComment-700087 Share on other sites More sharing options...
Guest RedLineGTR Posted February 25, 2004 Share Posted February 25, 2004 They "probably" will be but you need to find the specs of them to see if they are much different if i find some specs i will post it up. Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/#findComment-700089 Share on other sites More sharing options...
Jimbo2000 Posted February 25, 2004 Share Posted February 25, 2004 dont they not have specs (secretish?) Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/#findComment-700102 Share on other sites More sharing options...
Cubes Posted February 25, 2004 Share Posted February 25, 2004 Specs on cams for the Skylines GTST/GTR from R32-R34. http://www.tomei-p.co.jp/_2003web-catalogu...haft-specs.html EDIT: Looks like the only difference is the lobe center. So.. Grab your self a set of Adj. Cam gears. Skyline Boy, Nice looking R31, can't beat the black. Link to comment https://www.sau.com.au/forums/topic/35014-would-34-nur-gtr-cams-be-an-upgrade/#findComment-700364 Share on other sites More sharing options...
