snozzle Posted January 12, 2011 Share Posted January 12, 2011 Hey all, Planning a few mods for the gtr So i have a few questions for those who have been there done that already Firstly i plan on installing a Power fc DJ, a pair of adj cam gears and bigger injectors. aiming for around 320kw atw with my -7 turbos and stock camshafts. Does anyone have pictures of where they have successfuly got their vacuum feeds from for their 2 map sensors without removing the plenum etc? Has anyone gotten away with replacing cam gears by taking the top timing cover off only? if possible i want to avoid stripping the whole front end. Ive narrowed down my injector choice down to sard 700cc (black.blue) and sard 800cc (light green colour) Is it true that the 700cc injectors from sard are a true drop in item? no rewiring involved? has anyone used them before? What is the most effective way of holding a solid 1.2-1.3bar of boost? Ive had trouble with my profecb in the past, boost falls over at even 1 bar but it never used to do that when the standard boost solenoid was in there. Any advice is much appreciated! oz Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/ Share on other sites More sharing options...
DVS JEZ Posted January 12, 2011 Share Posted January 12, 2011 The profec b shouldnt drop off boost for no reason. What are ur settings? Does it spike then start to fall off. The 800s are a pain in the butt. U need to modify the stock rail to sit closer and then rewire the plugs. Afaik the 700s drop in. The cam gears are a tricky one. I suppose u can try and replace them without pulling the lower cover off. Try getting to the timing belt adjuster but. U have to lever and bend the lower cover a little. Put on TDC, Then use those strong paper clip holder things to hold the belt to the stock cam gears. Mark on the belt where the cam gear aligner is. Then one at a time pull the stock cam gears off the cams and swap witht the new ones. U will need some one to hold tension on the belt so it doesnt slip a tooth on the crank gear. I wouldnt recommend doing i this way but u can try and if it doesnt work or the belt slips etc then ur back to square one and u will have to pull the lower cover off to realign it all. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5622396 Share on other sites More sharing options...
snozzle Posted January 13, 2011 Author Share Posted January 13, 2011 Yep, it spikes then falls over instantly then comes back up then slowly dies off again. Dont know the settings off the top of my head. Are you running a profec? Well that rules the 800cc's out then haha. Can anyone confirm the 700cc's are drop in? The cam gear shortcut is sounding abit risky, i will just do it properly.. lol Thanks for your help dude. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5622856 Share on other sites More sharing options...
Beer Baron Posted January 13, 2011 Share Posted January 13, 2011 yes the 700s are drop in for a GTR and are a great injector. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5622930 Share on other sites More sharing options...
snozzle Posted January 13, 2011 Author Share Posted January 13, 2011 Ok thanks, 700cc's it is! Still need some sort of direction on installing the map sensors for the dejetro without taking the plenum off. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5623701 Share on other sites More sharing options...
SiR_RB Posted January 13, 2011 Share Posted January 13, 2011 Don't forget to upgrade ur fuel pump. Nismo/tomei drop in pumps are great ! Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5624147 Share on other sites More sharing options...
snozzle Posted January 14, 2011 Author Share Posted January 14, 2011 Car already has a walbro Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5624449 Share on other sites More sharing options...
paulr33 Posted January 14, 2011 Share Posted January 14, 2011 check the flow of the walbro pump and check what it flows at 12v how to install the map sensors is in the apexi documentation, check the PFC FAQ in my signature if you want 1.3bar, then run 1.3bar actuators or as close to the target as possible use your controller as a bleeder and make sure you are only trying to bleed a small amount, ie dont run a 7psi actuator and try to bleed 7psi Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5624455 Share on other sites More sharing options...
Beer Baron Posted January 14, 2011 Share Posted January 14, 2011 check the flow of the walbro pump and check what it flows at 12v how to install the map sensors is in the apexi documentation, check the PFC FAQ in my signature if you want 1.3bar, then run 1.3bar actuators or as close to the target as possible use your controller as a bleeder and make sure you are only trying to bleed a small amount, ie dont run a 7psi actuator and try to bleed 7psi agree with that point. have seen too many cars have problems with them to consider having one and not check it's flowing what it should be at whatever voltage it's receiving. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5624511 Share on other sites More sharing options...
snozzle Posted January 14, 2011 Author Share Posted January 14, 2011 Thanks for the advice, ill follow up on that. A pair oh HKS actuators would do me pretty well right now.. Ill keep a look out for a pair Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5624559 Share on other sites More sharing options...
DVS JEZ Posted January 14, 2011 Share Posted January 14, 2011 yep im running a profec b, i run 22psi nicely with 7psi actuators, try lowering the set gain and gain a little, trial and error, when lowering these it will probably lower the boost, Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5625091 Share on other sites More sharing options...
GTR_JOEY Posted January 14, 2011 Share Posted January 14, 2011 You need to modify the rail for 800cc's?, i though it was just changing the plugs over with a bit of crimping and soldering how do u go abouts bringing the rail closer? Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5625432 Share on other sites More sharing options...
snozzle Posted January 14, 2011 Author Share Posted January 14, 2011 im glad i dont have to bother with that now .. sard 700cc's have been purchased does anyone know how to use restrictors with the stock boost solenoid so that i can run more than 1 bar? it seems its a better boost controller than my profec lol DVS32R can you explain how you have setup your solenoid? Last time my car got tuned, i left it up to the tuner to install the profec, thinking they know how to do it right but it seems there must be a better way. Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5625602 Share on other sites More sharing options...
DVS JEZ Posted January 14, 2011 Share Posted January 14, 2011 You need to modify the rail for 800cc's?, i though it was just changing the plugs over with a bit of crimping and soldering how do u go abouts bringing the rail closer? I had to cut a slit in the mounting tabs on the stock rail enough so i could bend them to lower the rail about 10mm. It was dodgy but it worked. Especially when im impatient and wanted to start my fresh motor. Im sure the prifec is installed right. Go out and get ur settings an let me know what they are at? Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5625706 Share on other sites More sharing options...
GTR_JOEY Posted January 15, 2011 Share Posted January 15, 2011 Yep u sure did sound keen, ill see how i go when i get mine cheers for the reply! Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5625863 Share on other sites More sharing options...
snozzle Posted January 15, 2011 Author Share Posted January 15, 2011 LO setting (hits 1.1bar when i floor it then bleeds down to 0.85bar then creeps back up to 0.95bar) -54% -gain: 13% -set gain 0.50 x 100kpa HI setting (hits 1.2 bar then bleeds down to 1bar then creeps back up to 1.15bar) -62% -gain: 13% -set gain 0.66 x 100kpa these are the settings i have done myself, the boost control was alot worse than this when i got it back from my tuner, it would hit 1.2bar on HI setting then bleed down to 1 bar. by increasing the duty cycle of the wastegate and lowering the set gain, i managed to improve the average boost level but it seems that my solenoid is just not setup correctly, making it hard to get the settings right. im thinking that if i can set it up properly, manipulating the settings should be this hard My solenoid was mounted in the stock boost solenoids position, the vacuum line at the very back of the plenum was pulled out, this was the line that went to my actuators, a vac line was then put onto that nipple and back to the actuator as a pressure source. this time round, im going to mount the solenoid on the turbo side of the engine with much shorter and equal length lines to the actuators or.. i can manipulate the stock boost solenoid to give me 1.3bar of boost or i can just buy hks actuators lol Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5626077 Share on other sites More sharing options...
SiR_RB Posted January 15, 2011 Share Posted January 15, 2011 Are 700cc injectors on a gtr aiming for around 300awkw too big? Can you get the car to idle properly with them running a nistune ecu? There going for a good price on eBay at the moment. My tuner said there overkill I should be getting 550's or 600's at most, but they r way more expensive! Suppose it's good to have a it of extra room incase the engine gets rebuilt oneday and chase more power, just concerned with idling etc Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5626213 Share on other sites More sharing options...
GTR_JOEY Posted January 15, 2011 Share Posted January 15, 2011 (edited) Are 700cc injectors on a gtr aiming for around 300awkw too big? Can you get the car to idle properly with them running a nistune ecu? There going for a good price on eBay at the moment. My tuner said there overkill I should be getting 550's or 600's at most, but they r way more expensive! Suppose it's good to have a it of extra room incase the engine gets rebuilt oneday and chase more power, just concerned with idling etc PM me mate, and ill show ya where to get some cheap brand new injectors Edited January 15, 2011 by GTR_JOEY Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5626344 Share on other sites More sharing options...
snozzle Posted January 15, 2011 Author Share Posted January 15, 2011 Aslong as they are trimmed down, there should be no difference, i have seen 420awkw made from these 700cc injectors (tangomatts r34 gtr nur) and thats more than ill ever be able to achieve so its got the head room i need too, especially if i want to use e85 later on even these are kind of small... Only 2 things i need to determine now is how im going to do my dejetro install and boost control and im set Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5626383 Share on other sites More sharing options...
Kaido_RR Posted January 15, 2011 Share Posted January 15, 2011 Aslong as they are trimmed down, there should be no difference, i have seen 420awkw made from these 700cc injectors (tangomatts r34 gtr nur) and thats more than ill ever be able to achieve so its got the head room i need too, especially if i want to use e85 later on even these are kind of small... Only 2 things i need to determine now is how im going to do my dejetro install and boost control and im set if i remember right i pay $300 ish for install of dejetro and injectors by hyperdrive. I was too lazy to install the sensor. +1 For HKS actuators, got mine set to 16psi (by pure luck lol) and my blitz id3 bleed it out to 19psi and holds it firm till redline with a set of gt-ss Link to comment https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/#findComment-5626407 Share on other sites More sharing options...
