Hey all,
Planning a few mods for the gtr So i have a few questions for those who have been there done that already
Firstly i plan on installing a Power fc DJ, a pair of adj cam gears and bigger injectors. aiming for around 320kw atw with my -7 turbos and stock camshafts.
Does anyone have pictures of where they have successfuly got their vacuum feeds from for their 2 map sensors without removing the plenum etc?
Has anyone gotten away with replacing cam gears by taking the top timing cover off only? if possible i want to avoid stripping the whole front end.
Ive narrowed down my injector choice down to sard 700cc (black.blue) and sard 800cc (light green colour)
Is it true that the 700cc injectors from sard are a true drop in item? no rewiring involved? has anyone used them before?
What is the most effective way of holding a solid 1.2-1.3bar of boost? Ive had trouble with my profecb in the past, boost falls over at even 1 bar but it never used to do that when the standard boost solenoid was in there.
Any advice is much appreciated!
oz
https://www.sau.com.au/forums/topic/350140-rb26-mod-questions/
The profec b shouldnt drop off boost for no reason. What are ur settings? Does it spike then start to fall off.
The 800s are a pain in the butt. U need to modify the stock rail to sit closer and then rewire the plugs. Afaik the 700s drop in.
The cam gears are a tricky one. I suppose u can try and replace them without pulling the lower cover off.
Try getting to the timing belt adjuster but. U have to lever and bend the lower cover a little.
Put on TDC, Then use those strong paper clip holder things to hold the belt to the stock cam gears. Mark on the belt where the cam gear aligner is. Then one at a time pull the stock cam gears off the cams and swap witht the new ones. U will need some one to hold tension on the belt so it doesnt slip a tooth on the crank gear.
I wouldnt recommend doing i this way but u can try and if it doesnt work or the belt slips etc then ur back to square one and u will have to pull the lower cover off to realign it all.
Yep, it spikes then falls over instantly then comes back up then slowly dies off again. Dont know the settings off the top of my head. Are you running a profec?
Well that rules the 800cc's out then haha. Can anyone confirm the 700cc's are drop in?
The cam gear shortcut is sounding abit risky, i will just do it properly.. lol
Thanks for your help dude.
check the flow of the walbro pump and check what it flows at 12v
how to install the map sensors is in the apexi documentation, check the PFC FAQ in my signature
if you want 1.3bar, then run 1.3bar actuators or as close to the target as possible
use your controller as a bleeder and make sure you are only trying to bleed a small amount, ie dont run a 7psi actuator and try to bleed 7psi
agree with that point. have seen too many cars have problems with them to consider having one and not check it's flowing what it should be at whatever voltage it's receiving.
im glad i dont have to bother with that now .. sard 700cc's have been purchased :)
does anyone know how to use restrictors with the stock boost solenoid so that i can run more than 1 bar? it seems its a better boost controller than my profec lol
DVS32R can you explain how you have setup your solenoid? Last time my car got tuned, i left it up to the tuner to install the profec, thinking they know how to do it right but it seems there must be a better way.
You need to modify the rail for 800cc's?, i though it was just changing the plugs over with a bit of crimping and soldering
how do u go abouts bringing the rail closer?
I had to cut a slit in the mounting tabs on the stock rail enough so i could bend them to lower the rail about 10mm. It was dodgy but it worked. Especially when im impatient and wanted to start my fresh motor.
Im sure the prifec is installed right. Go out and get ur settings an let me know what they are at?
LO setting (hits 1.1bar when i floor it then bleeds down to 0.85bar then creeps back up to 0.95bar)
-54%
-gain: 13%
-set gain 0.50 x 100kpa
HI setting (hits 1.2 bar then bleeds down to 1bar then creeps back up to 1.15bar)
-62%
-gain: 13%
-set gain 0.66 x 100kpa
these are the settings i have done myself, the boost control was alot worse than this when i got it back from my tuner, it would hit 1.2bar on HI setting then bleed down to 1 bar.
by increasing the duty cycle of the wastegate and lowering the set gain, i managed to improve the average boost level but it seems that my solenoid is just not setup correctly, making it hard to get the settings right.
im thinking that if i can set it up properly, manipulating the settings should be this hard
My solenoid was mounted in the stock boost solenoids position, the vacuum line at the very back of the plenum was pulled out, this was the line that went to my actuators, a vac line was then put onto that nipple and back to the actuator as a pressure source.
this time round, im going to mount the solenoid on the turbo side of the engine with much shorter and equal length lines to the actuators
or.. i can manipulate the stock boost solenoid to give me 1.3bar of boost
or i can just buy hks actuators lol
Are 700cc injectors on a gtr aiming for around 300awkw too big? Can you get the car to idle properly with them running a nistune ecu?
There going for a good price on eBay at the moment.
My tuner said there overkill I should be getting 550's or 600's at most, but they r way more expensive!
Suppose it's good to have a it of extra room incase the engine gets rebuilt oneday and chase more power, just concerned with idling etc
PM me mate, and ill show ya where to get some cheap brand new injectors
Edited by GTR_JOEY
Aslong as they are trimmed down, there should be no difference, i have seen 420awkw made from these 700cc injectors (tangomatts r34 gtr nur) and thats more than ill ever be able to achieve so its got the head room i need too, especially if i want to use e85 later on even these are kind of small...
Only 2 things i need to determine now is how im going to do my dejetro install and boost control and im set :)
if i remember right i pay $300 ish for install of dejetro and injectors by hyperdrive.
I was too lazy to install the sensor.
+1 For HKS actuators, got mine set to 16psi (by pure luck lol) and my blitz id3 bleed it out to 19psi and holds it firm till redline with a set of gt-ss
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
