Hey guys, just got myself a 99 S2 Stagea and i'm pretty sure the ex manifold to turbo gasket is gone, its stock as a rock and on full boost you hear a screech its not metalicy like a turbo but def sounds like an exhaust leak, performance doesn't seem effected it idles beautifully and if you don't hit full boost sounds good too, cant be fked doing it myself so wondering if anyone can recommend someone on Gold Coast or local area to do the work at a reasonable price?
Cheers.
Cheers.
I had the same car, with the same thing. Spent ages looking for exhaust leaks, turned out to be damage to the turbo impellor. the out of balance caused the screaching noise.
if you want me to pull your turbo off i can for some cash or beverages
i'm down in robina
i changed my dump pipe and changed the gasket while i was there
not too hard, just fiddly and annoying
Cheers for the offer Pipster will see how I go and yeah was thinking may as well throw a front pipe on, hmmmm had my first good look at it today, pulled intaek pipes off and that and checked pipes and clamps and may well be Turbo, reckon I have a noisy lifter too :( at idle the top is a little noisy, will have to drop the oil and see what happens, does idle perfect at 850 though and not miss a beat. Getting auto diff and transfer case serviced Monday just to be sure too
Really so it's a Stagea thing? i've had numerous turbo cars inc an s1 r33 and never heard this sound although the seller of the car did say when i questioned it "oh i thought that's how they all sounded" I know the normal intake sound but this is def different to anything I have heard before I thought gasket or impeller getting sucked into housing.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
