Hi Guys,
I am going to modify my R32 GTR to run E85, my 1000cc injectors just turned up today!
And I have been trying to search around for fuel supply options for E85
I have currently got the following mods:
Rebuilt RB26 with forged internals
2860-5's
Nismo AFM's
full 3in exhaust
660cc injectors
Walbro fuel pump
Turbosmart E-Boost Street
std intercooler
K&N Filter in airbox
It made 350rwkw on a dyno dynamics @ 21.5psi
and made 317rwkw on a mainline dyno @ 20psi
Most people have told me that i'd need twin pump and surge tank setup to really make benefit of e85. but i want to try and steer clear from a surge tank in the boot because i've heard that there is fuel smell issues.
so an under car surge tank would be an option but there is very limited room underneath a R32, so where have people mounted surge tanks under the car if they have.
Also have anyone used any twin intank pump setups?
This would be the most attractive for me because it would be more simpler.
I have done track days and may do 2-3 a year, so its not a purpose track car. i dont drive it regularly hence fuel ecconomy and availability isnt much of an issue for me.
Even if i were to take it to the track again i would take my 3 20L jerry cans and make sure the fuel level doesnt drop below 1/2 a tank. so fuel surge isnt going to be a problem on track.
So if anybody has any results with a twin pump setup in tank please share it with me, it seems to be popular with the BMW guys, and on other forums like the WRX & EVO ones.
Cheers,
https://www.sau.com.au/forums/topic/350161-twin-intank-pumps-for-a-gtr/
  • Replies 61
Posted Images
You wont get any fuel smells if you do it properly with teflon braided lines, but it is still illegal.
Twin intank walbro's would be the go but a single GTR Nismo/Tomei should just handle that power.
^^^ on e85? Doubtful.
Powertune do a bolt in kit for twin pumps in tank. Do a search it's been covered before or call them up
Yeah there is a similar kit around too @ half the price, one of my customers just came in with one.... forgot who did it though.. :domokun:
mmm I'm interested. if you can find out who sells them I might grab one for my new car. want to switch it to E85. currently running a nismo pump, already has 1000cc injecotrs, after a nice 380kw or so with the 2530s it has but don't think the nismo pump will do it.
Yeah, if you could find out who the kit was through it would be appreciated!!
I'm just wondering how difficult it would be to modify the cradle and put together a bracket for the twin pumps to sit in?
also at what limit have people found the std fuel lines to run out of flow? what power levels do you have to run twin lines?
Cheers,
  • 9 months later...
I made my own twin walbro bracket. It surges at around 1/4 tank in my Stagea but that is due to the underseat tank mounting more than the pickup design.
A surge tank would be the best for track, even a small one may do the job.
Nismo intank pump, 400rwkw - no issues that we could tell from this. ID1000's
looked into all of this twin this, surge that, undercar etc... wasn't needed in the end.
pretty much same setup as well, built 26, 2530's.
on E85??
It's funny how similar our setups are.... but I am using HEAPS more fuel than you. Different ways of tuning to achieve the same result?
I'm pretty happy with the twin pumps i have in tank.
i managed to get them mounted in the stock cradle. after a heap of fiddling with the wiring they're running good now.
it turned out to be a bad connection clip in the fuel tank lid. removed it and ran an earth wire straight to the pumps and its fine now.
still a little low on power.
353rwkw on 24psi but hopefully with either poncams or a bigger cat back exhaust i can stretch some more out of it.
the exhaust is a little restrictive after the front pipe, front pipe is twin 70mm going into at least a 90 or 100mm collector and necking down to 80mm exit. then the decat has a 76mm flange so there is a fair restriction there.
Sort that out! It's all over the place! Its amazing what a well thought out exhaust does for these things... I made more power on less boost on SMALLER turbo's with an exhaust that works!
i was thinking the same thing earlier,
a decent turbo back exhaust will do wonders.. 3" is small for those huffers.
Edited by jangles
i suppose when you start shoving 24psi of boost through -5's there is a fair amount of air flow!
those restrictions are probably causing the graph to table top.
the exhaust does sound quite full of air when at WOT.
at least now we know that 3in will flow 350rwkw but at slightly higher boost.
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
