Its done just got to post it
I competed and paid via the online forms around two weeks ago and haven't received any correspondence about membership, just wondering if you guys have received it yet as I've signed up for the vicwrx track day this month on the 21st n it seems they require validation of club membership.
Thanks, Jason
do you type
cheers
the baron
after every post?
cheers.
plattsy.
Why yes, yes I do.
Cheers
The Baron
PS On some other forums I usually try to put an adjective or descriptor between 'The' and 'Baron' depending on the nature of the topic and this can be quite difficult in order to avoid repetition, but its the little things that amuse :-)
Cheers
The somewhat OCD Baron - see there's an example
Why yes, yes I do.
Cheers
The Baron
Cheers
haha touche' mate!
needs more action in members section.... maybe a members only wasteland ala' nsw?
Received today in the mail, thanks. No stickers in envelope however, membership card, lanyard and letter. Can I lease request. Couple of stickers.
Thanks. Steve
Yeh I'll send the out ASAP
Thanks
  • 4 weeks later...
    • Cleaner signal so timing is more accurate at all rpm also found it to start more on first rotation but could also be I've nailed prime and crank fuel. For under $400 and 30mins of your time, its a good solution especially once the optical sensor does start to play up you won't notice it until in higher rpm and it heat soaks.
    • On a 400hp RB, what benefits other than "it's not 30+ years old" are you seeing from the NZ Wiring Kit trigger setup? If it were me going to change triggering, my belief would be to go for a crank trigger to remove the issues caused by what people claim is belt stretch etc, but that's from my understanding a much larger issue for super high power, rather than those in the 400hp and below club.
    • The NZ wiring kit is a 1/3 the price and will be perfectly fine for your application, I've ran one for 6+ years and many others have. Comes as a full plug into factory connector and the settings for a Link. https://www.nzwiring.com/index.php/product/trigger-kit/ Always comes back to the tuners knowledge and experience with a tuning platform. It takes years to become proficient and learning all aspects and capabilities. I've been using Links for 16 years now (rb and sr paltforms) and always learning something new with adding tables, diagnostics and data logging. Stay 98 for the usability and keep it simple so you can enjoy the car more. With experience I'll give you a current example of the industry I am in. They use Motec m190 and only use VE tuning when they have a torque mapping available and would solve the "PARITY" issues that plagues the category all because the muppet doing the tuning doesn't understand the platform or want to learn it and the product seller have no idea on its full capabilities ( I had a good laugh as when firing up an older car that just got completed and they didn't understand the injector scaling or how to change it for different fuel being used)
    • I'm sure there are specific hygrometers for it. But if you can just throw a high enough ranged temp sensor (theromcouple that came with your DMM, for example) into a pot of it on the BBQ, you can see when it boils.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
