95 25t
1. Twin dump pipe full maundrel bent system 3 inch turbo to tip
2. Turbosmart bleed @ 11 psi
3. K&N panel filter (hehe - 1kw)
Rest of the car stock.
How many kws would I have gained do u think?
Next on my list is hybrid fmic, then PowerFC. Hoping for close to 200rwkw
with all that plus good tuning... :bs!: ?
https://www.sau.com.au/forums/topic/35025-how-much-power-do-i-have-not-much/
A power run should set you back arpund $40.
Woah! Is that all... Thought it would be at least $100. Anybody know a good dyno on Brisvegas northside?
Be pretty happy with 165rwkw, that would mean 30kw for $1300. Mmmm $1700 for hybrid fmic but i have nfi how much power gain from that maybe 10 rwkw? I've heard of peeps getting 20 rwkw's out of powerfc though, maybe another $1500 + tune. Should be near my goal then for about $3150.
Should I be looking @ stonger clutch before all this or will standard b ok up to 200 rwkws? Woops forgot a whiteline kit too didnt i...
Hey stop newby bashing u :flamer:
not heaps because with those sorts of mods the std ecu runs rich as we all know and have experienced. I reckon around 140 - 150 rwkw depending on dyno.
Your future mods sound good but I think when you get the power fc, thats when you can make the most of the mods u have.
well as a base idea for u. I got a 12/93 r33 gtst. When i dynoed it, it had a cat back 3 inch, pod filter with no air feed, and boost controller set on 13psi and i made 213rwhp(bout 160rwkw) u would be around that mark i would think. Give or take 10 kw
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
